Thread Number: 43153
Question about gluing Maytag Damper Pads. A712 |
Post# 634790 , Reply# 1   10/27/2012 at 23:03 (4,198 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Actually, the manual says to use Maytag RUBBER adhesive, not Rubber cement/contact adhesive. It is a yellow/orangish color. My tube says it is part 055978.
The instructions on my tube of rubber adhesive say to "coat one surface, let dry for 1 minute until tacky, then bond." When I have replaced damper pads and used this adhesive I have had no trouble shifting the pads a bit one way or the other initially. Then I leave them alone to set. |
