Thread Number: 43211
Appliances (4) Westinghouse RETRO 1970's Harvest Gold |
Post# 635586   10/31/2012 at 23:32 (4,206 days old) by xpanam (Palm Springs California )   |   | |
Post# 635591 , Reply# 1   10/31/2012 at 23:51 (4,206 days old) by rp2813 (Sannazay)   |   | |
Post# 635658 , Reply# 3   11/1/2012 at 08:01 (4,206 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This DW was a great performer [ reliability was a completely different matter ] and in fact they copied some aspects from the KD-15 KA DWs and in CRs tests in 1966 it equaled KA and WP and all three of these brands had a check-rated rating.
The range was a good performer but unfortunately it is the continuous cleaning model, WH had lots of problems with the CC porcelain finish flaking off the metal oven liner so you could end up with bits of glass in your food [ covered casseroles only ] LOL.
There refrigerators were so so, you could usually count on soft ice cream and frozen lettuce in there refrigerators and frozen evaporator drain pans, I must have added a hundred auxiliary drain heaters to these refrigerators back in the time any were actually still in regular use. |
Post# 635661 , Reply# 4   11/1/2012 at 08:06 (4,206 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
I had a WH dishwasher like this but portable. It was a great cleaning machine as long as you had copious amounts of very hot water available. I gave it to my first ex-husband that lived in an apartment building with water temps around 160F and it washed great! You could get a lot in that machine, too.
Post# 635665 , Reply# 5   11/1/2012 at 08:28 (4,206 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Yeh, these are BOL-to-MOL Westy's...!
What's nice about the fridge is you got a lot of drawers, shelves & bins for the money, with it being a top freezer model (and those nice wide doors & shelves are what I like & miss! --Probably because space needed for Holiday food storage is coming!)... I'm disappointed that the range isn't the next higher up w/ two 8", a cook top light & self-cleaning oven; otherwise it's very much reminiscent of the electric ranges used in my grade school Home Economics classes (never actually took Home Ec', just saw the app's used on occasion & the B/I's used by the teacher--& many years later after I'd graduated, no telling what must be used in the class rooms now...!)... The D/W seems to be the one-knob Westinghouse my aunt had in her apt. & very much like my folks' D&M-built Bradford (a universal design, used by a lot of manufacturers, who weren't Maytag, Whirlpool or GE) and a plus if it cleans decently, though not much can be expected of reliability, if my parents hardly kept theirs, after the one small break down that must not have been worth any bother to fix... -- Dave |
Post# 635690 , Reply# 6   11/1/2012 at 12:05 (4,206 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
"WH had lots of problems with the CC porcelain finish flaking off the metal oven liner so you could end up with bits of glass in your food [ covered casseroles only ] LOL."
I had a '73 40-inch Westy with CC for quite some time, and never had that problem. That was in spite of many, many cleanings of the coating*. That range gave several problems, but not that one. * A CC coating that's "overloaded" (meaning so much soil it exceeds the catalyst's ability to burn it off) can be restored to function with straight sudsy ammonia and a soft-bristled scrub brush. After scrubbing, run the oven at 500 degrees for a little while to burn off the ammonia smell and any remaining oven cooties. |
Post# 635702 , Reply# 7   11/1/2012 at 12:35 (4,206 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 635706 , Reply# 8   11/1/2012 at 12:48 (4,206 days old) by DADoES (TX, U.S. of A.)   |   | |
Continuous clean has (or had, since they're no longer on the market far as I've noticed) a special porous (enzyme?) coating that spread, absorbed, and dissipated grease & food soils at "normal" oven temperatures. There was no high-heat pyrolytic cleaning cycle involved. They were advertised with taglines such as "your oven is always clean" ... which wasn't so much the case in real-world conditions. |
Post# 635710 , Reply# 9   11/1/2012 at 12:53 (4,206 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Most CC ovens I saw were in the rental homes. Ok in theory but tenants for the most part didn't understand or flat out didn't care about how to make the best use of the system and scraped the ovens or worse used spray on oven cleaner and ended up trashing the coatings and rendering the system useless...
RCD |
Post# 635714 , Reply# 10   11/1/2012 at 13:10 (4,206 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 635739 , Reply# 12   11/1/2012 at 15:39 (4,206 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Here's how you fix a CC oven that has been sprayed with oven cleaner:
1) Use the ammonia trick described in my previous post. This loosens up and re-dissolves the dried oven cleaner. 2) Now re-scrub with straight vinegar. This neutralizes the oven cleaner and the ammonia. Rinse very well with lots of clean water. 3) Run the oven a while at 500 to burn off residues. If white traces re-appear after doing this, it may be necessary to re-clean the oven starting again with Step 1. 4) Tell the tenant they may not be bright enough to live with humans. |
Post# 635784 , Reply# 13   11/1/2012 at 19:27 (4,205 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 635789 , Reply# 14   11/1/2012 at 19:35 (4,205 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 635821 , Reply# 15   11/1/2012 at 22:08 (4,205 days old) by jamiel (Detroit, Michigan and Palm Springs, CA)   |   | |
The surface is porous and will spread out a splatter of grease (rather than letting it create a droplet), which will, over time, allow the grease to oxidize and disappear. I had an aunt with a continuous cleaning oven which inevitably would smoke and smell when she was doing the turkey on Thanksgiving (the extended baking time did the "cleaning".
