After very few months of work on this machine really a challenge to get it working again!
Now the problem is that it leaks from the tub... I mean, I tried to fill it and no doprs went out, I left the water in few days and all goes well... once I've assembled the motor again (it's been rewired cause it warmed up and the starting coil was out of order) the tub drops again a lot...blast!
Once it get filled some drops went out fron door gasket (tub side), but no more workin on (I suppose due to the suds). It's a river instesad what you see from the back tub fascia!!
Never found nothing to replace neither how to rebuild the spin solenoid which is missing.
Thansk a lot for every help or council to get this restoration to the end
BYE!
Diomede
