Thread Number: 43432
Kenmore tub grommet - belt drive washer question |
Post# 638857 , Reply# 1   11/13/2012 at 19:47 (4,181 days old) by bendixmark (Winchester Mass)   |   | |
You wouldnt want to do that.When replacing the grommet you want to put a coating of clear permatex silicone on it to seal against leaks then replace the center seal as well while your in there. |
Post# 639003 , Reply# 3   11/14/2012 at 08:56 (4,181 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 639061 , Reply# 4   11/14/2012 at 14:47 (4,180 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 639064 , Reply# 5   11/14/2012 at 14:56 (4,180 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Washer Newbie -
What is the exact model number of your machine? You said it is a 1984 80 series, correct? Is it a suds-saver or a non-suds? If you don't know the model number, do you remember which pump you bought? I ask because I want to determine how water is flowing. Suds models and most similar machines built before mid-1982 will flow water in two directions through the tub grommet. This in my experience increases the likelihood that the grommet will leak during the wash/rinse agitate phase, which sends water from the pump up through the grommet into the tub. On the other hand, non-suds models built after mid-1982 do not recirculate water through the grommet, and it is used simply as a drain plug of sorts during agitation. Water does flow through it during drain however. Your chances are probably marginally better of re-sealing a leaky grommet if you have a model that DOES NOT send water up through the grommet during agitation. I can tell you either way if you have a model number. It would be a toss-up for me if this were my problem. Pulling the outer tub and replacing the 93553 grommet will almost always repair a leak there. Unless the baseplate is rusted to the point that the grommet cannot sit flat, a new 93553 is a gift to the machine once the old one starts leaking. These are NLA so grab one at Sears while you can. Pulling the tub though may be difficult if the center grommet, which must be changed also, is stuck to the centerpost, especially if you goo'ed it in with POR-15. This will also at times cause weakened edges on the tub to break off where it meets the center grommet (I call this the tub lip). This makes a re-seal with a new center grommet difficult. I used to say impossible, until doing some repairs with 2-part epoxy at weak points. If you know your tub doesn't leak from the center grommet (they almost always do at some point, at least the later production models) I would try sealing the old 93553 first, but not expect 100% success. If that works, cool, stop there. If not, proceed to pull the tub, replace the 93553 grommet AND the center grommet, seal the centerpost down lower with POR-15 now that more of it is exposed, and re-assemble, knowing that the tub may need some work prior to completion of the project. If you do decide or need to pull the tub, let us know as I have some removal tips I'll share at that time. Gordon |
Post# 639140 , Reply# 7   11/14/2012 at 20:59 (4,180 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Newbie -
While I understand and largely agree with the comments made directly above, if you're doing this work for the first time, and want to pull the tub from the machine just once, your chances of success are better with a new grommet. If they're only 8-bucks, all the more reason as far as I see it. I have installed new grommets in at least half the machines I've serviced. However, I was not running a business, I was doing a hobby. I did this because I never wanted to hear from these customers again, unless they wanted to buy another washer, and the new grommets are much more forgiving and will seal more surely than a used one without using sealer in the grommet area. If you look at the picture on Sears' site, the sealing surface is very sloped. It is this way for compression reasons under the tub. A tub will compress this surface and seal all-around, like pressing your face up to a glass window, even when there is some deformations and corrosion on the tub. Depending on the detergents, water, and chlorine used on the old grommet, some of them come out of machines nearly flat. Those that were flat and feeling a bit dried from bleach were the first ones I replaced, leaking or not. If you don't want to work with sealer and are ok with the 8-bucks, I'd buy the new grommet. Gordon This post was last edited 11/14/2012 at 21:57 |
