Thread Number: 43452
Kenmore Ultra Wash |
Post# 638945 , Reply# 1   11/14/2012 at 00:00 (4,181 days old) by appnut (TX)   |   | |
If it's not in engish I won't be able to help you. Do the letters on the dial correspond with letters associated with some of the buttons? A is probably Pots & Pans. Heated prewash, rinse, heated main wash, rinse, and final rinse that's also heated. Normal is prewash, wash, and 2 rinses. Light/china is wash and two rinses. If there's a water heat button, that will raise the water temperature of the main wash and final rinse. Is this the type of information you are asking for? |
Post# 638949 , Reply# 3   11/14/2012 at 00:19 (4,181 days old) by rimpley ()   |   | |
And the dial..so the letters above the buttons have something to do with those on the dial? |
Post# 638957 , Reply# 4   11/14/2012 at 00:47 (4,181 days old) by appnut (TX)   |   | |
A is Pots & Pans, B is Normal, C is Light/China, and D is quick rinse or rinse & hold. I believe the options are heated dry and cool dry. But there could be a slight variation. chaud could also mean a water heat option for main wash and final rinse and econo could mean water heat option is cancelled as well as heated dry.
All cycles are like I described above. Quick rinse or rinse and hold (D) is just the last rinse or the two rinses after the main wash. this is a very good performing machine. Warm/Tiede is plate warm cycle. |
Post# 638959 , Reply# 5   11/14/2012 at 01:08 (4,181 days old) by rimpley ()   |   | |
Thanks! You rock! We paid $25 for it and if it works as well as hubby thinks it might then he'll be happy. Sounds like a freight train, but we can live with that. |
Post# 638985 , Reply# 7   11/14/2012 at 06:52 (4,181 days old) by rpms (ontario canada)   |   | |
I had this dishwaher 10 years ago in my first condo. Yes, it is noisy when it fills and starts to wash at the same time. I could never figure out why it was made like that? Once filled it quiets down quite a bit.
If you start the dishwasher on 'A' it is a wash,rinse,wash,rinse,rinse. The first and second wash is heated and the final rinse. If you have 'B' pushed, only the final rinse is heated. To have a shorter wash with heated water, you could push'A' and advance it to 'B' or 'C'. To use to he 'rinse only', advance to 'D' and push econo dry to shut off the heated dry. I think only the 'A' cycle could be delayed? |
Post# 638994 , Reply# 8   11/14/2012 at 07:39 (4,181 days old) by rpms (ontario canada)   |   | |
I belive if you have 'D' pushed, it shuts off the heated rinse and dry.
You could have 'D' pushed and start the dishwasher on 'B' or 'C' you would not have a final heated rinse. I believe I used to do that to get rid of prep dishes quickly. Push 'D' and advance the dishwasher to 'C'. You would get a 5 minute wash, 3 minute rinse and a 5 minute final rinse. It was a quick cycle and everything would be clean. I could be wrong, my dishwasher had a signal that glowed when the water was heating. Having 'D' pushed always shut it off. |
Post# 639028 , Reply# 10   11/14/2012 at 11:59 (4,181 days old) by rpms (ontario canada)   |   | |
Post# 639497 , Reply# 11   11/16/2012 at 20:40 (4,179 days old) by Iowegian ()   |   | |
Just wait until Guy Fieri puts Hot Chaud on the menu of his next restaurant... |
Post# 639512 , Reply# 12   11/16/2012 at 21:39 (4,179 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
