Thread Number: 43456
Bosch Dishwasher |
Post# 639001   11/14/2012 at 08:47 (4,181 days old) by ozzie908 (Lincoln UK)   |   | |
I got My aged Mother a Bosch dishwasher and just a few days ago its stopped cleaning the upper rack.
I tried yesterday to add more water see if that helped but no it refuses to wash the top stuff I cannot see any blockages but that does not mean there is not one somewhere so if anyone knows any easy way to find out could you let me know please? Austin |
Post# 639008 , Reply# 1   11/14/2012 at 09:24 (4,181 days old) by marthalover4eve ()   |   | |
may need a new recirculation pump |
Post# 639067 , Reply# 3   11/14/2012 at 15:15 (4,180 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 639071 , Reply# 4   11/14/2012 at 15:34 (4,180 days old) by Logixx (Germany)   |   | |
All Bosch dishwashers alternate the spray. It could something as easy as a clogged spray hole in the upper spray arm that keeps it from spinning. Or something stuck in the path to upper arm (happened to my grandma, who didn't insert the filter properly). Worst case would of course be, if the spray charger thing is stuck on lower rack wash. Which model is it? The new models have a safety switch that can be overridden with a magnet - I was almost shocked at how easy one can make these new models wash with an open door.
Post# 639078 , Reply# 5   11/14/2012 at 15:45 (4,180 days old) by ozzie908 (Lincoln UK)   |   | |
something every day !
The last dishwashers I remember doing alternating sprays were AEG I never realised that Bosch did them too. Cannot recall the model number will make a note when there again have done all the checking of spray arms etc no blockage at all so its a question of taking it to bits I will let her know its fixable as she may be looking for a new one. Thank you for sharing this with me :) Austin |
Post# 639109 , Reply# 6   11/14/2012 at 19:45 (4,180 days old) by joe_in_philly (Philadelphia, PA, USA)   |   | |
Post# 639452 , Reply# 9   11/16/2012 at 17:12 (4,178 days old) by logixx (Germany)   |   | |
Our 2006 Bosch sprays either the lower or the upper basket (including the ceiling shower). On varioSpeed, all jets runs at once. My new one with the activeWater system sprays either from the lower, middle or upper jets. On varioSpeed, it'll spray from the bottom and the ceiling or just from the middle arm. All three jets never work at once.
Old Bosch: vs. new one: ?hd=1 |
Post# 639619 , Reply# 10   11/17/2012 at 06:42 (4,178 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 640393 , Reply# 11   11/20/2012 at 06:41 (4,175 days old) by chris74 ()   |   | |
I can imagine that they're worse than conventional spray technique... |
Post# 640394 , Reply# 12   11/20/2012 at 06:45 (4,175 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 641064 , Reply# 14   11/23/2012 at 14:39 (4,171 days old) by sudsmaster (SF Bay Area, California)   |   | |
I have an SHU43C05 Bosch DW. I don't think it alternates between lower and upper. But I have noticed that it's necessary to push the upper rack all the way back so the nozzle on the back of the top rack fits into the spray tube that comes up from the lower level. Usually it's no problem but sometimes a long item (like a mixing spoon) that is laid down on the upper rack will slip rearward and block engagement of the spray tubes. Perhaps that is the situation with yours?
Post# 641155 , Reply# 15   11/24/2012 at 03:08 (4,171 days old) by ozzie908 (Lincoln UK)   |   | |
At this present time for what ever was the issue it seems to have cleared itself. It will warrant further investigation when I have time as it was a flawless cleaner before it went doolally. When it goes next time I will take it apart and find out what its problem is and will duly report all findings.:)
Thank you for all your helpful comments I knew it would be a great place to ask ! Austin |
Post# 649102 , Reply# 16   12/26/2012 at 08:15 (4,139 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 649478 , Reply# 17   12/28/2012 at 05:53 (4,137 days old) by ozzie908 (Lincoln UK)   |   | |
So after using the thing over and over with just the bottom rack working I took it apart yesterday as had an afternoon of boredom to put up with.
I found the only way I could get at the disc that goes round to alter the direction of the water was to remove the upper spray feed pipe and peer into the hole there is the white plastic disc which would move with the tip of a screwdriver so I turned it around to where the main jet went up to the top rack there is a smaller hole feeding the lower rack too and can you believe the damn thing worked just perfect !!! So at least when I collect the Miele over the weekend its good not to have to rush to install it as my Mum is 2.5 hours away. Nice one Austin you should have looked before declaring the Bosch unfit to work.... |
