Thread Number: 43698
KDW-7 Kitchenaid Varicycle by Hobart |
Post# 642195 , Reply# 1   11/27/2012 at 23:03 (4,167 days old) by lazymeadow ()   |   | |
Just in case I do have a fairy godmother or something, I believe my problem is in the fill valve. Is this something that's fixable? |
Post# 642198 , Reply# 2   11/27/2012 at 23:27 (4,167 days old) by rp2813 (Sannazay)   |   | |
Post# 642201 , Reply# 3   11/27/2012 at 23:44 (4,167 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 642262 , Reply# 4   11/28/2012 at 08:13 (4,166 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 642263 , Reply# 5   11/28/2012 at 08:22 (4,166 days old) by lazymeadow ()   |   | |
www.automaticwasher.org/cgi-bin/T... It is this one, in white! |
Post# 642338 , Reply# 7   11/28/2012 at 14:43 (4,166 days old) by rp2813 (Sannazay)   |   | |
Post# 642523 , Reply# 8   11/29/2012 at 05:50 (4,165 days old) by appnut (TX)   |   | |
Post# 642615 , Reply# 11   11/29/2012 at 15:41 (4,165 days old) by bajaespuma (Connecticut)   |   | |
Post# 642617 , Reply# 12   11/29/2012 at 15:47 (4,165 days old) by rp2813 (Sannazay)   |   | |
Post# 642621 , Reply# 13   11/29/2012 at 15:57 (4,165 days old) by lazymeadow ()   |   | |
that was weird this one should work sorry! CLICK HERE TO GO TO lazymeadow's LINK |
Post# 643598 , Reply# 16   12/2/2012 at 21:49 (4,162 days old) by lazymeadow ()   |   | |
There was a crack in the blue plastic! Now I just need to replace that... |
Post# 644120 , Reply# 18   12/4/2012 at 21:48 (4,160 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You need a new inlet valve, you should never use two hose washers, just one good or new one and Teflon tape is never used on the threads of an inlet valve, the threads are not like pipe threads where the sealing action is in the threaded area, so adding any type of thread sealant can cause problems and never helps matters. |
Post# 644121 , Reply# 19   12/4/2012 at 21:48 (4,160 days old) by rp2813 (Sannazay)   |   | |
