Thread Number: 43738
Duet and Frontloader lint filter access |
Post# 642669 , Reply# 2   11/29/2012 at 18:48 (4,165 days old) by applianceguy47 ()   |   | |
Then simply reinstalled the panel.
Post# 642670 , Reply# 3   11/29/2012 at 18:48 (4,165 days old) by applianceguy47 ()   |   | |
closer. |
Post# 642671 , Reply# 4   11/29/2012 at 18:50 (4,165 days old) by applianceguy47 ()   |   | |
closer 2
(nervous laugh) I didn't know there was a piece of pink foam under the washer. |
Post# 642705 , Reply# 6   11/29/2012 at 19:55 (4,165 days old) by yogitunes (New Jersey)   |   | |
Wonderful thinking for something that should have been there in the first place....thats using your head.....and thinking outside the box.....suprised no one has thought of this before...even the manufacturer....better patent the idea
if I may add a few ideas, and others may have some as well..... I have used car door edge moulding for around openings like this, and they come in colors..... also, could have used one of the billet style door trim that is used on many automotive gas door applications, this would provide a door, with latch... |
Post# 642792 , Reply# 8   11/30/2012 at 06:37 (4,164 days old) by yogitunes (New Jersey)   |   | |
something like this would be a possible cover option.....
door trim is usually rubber, flexible, and can be cut to size.....usually about 1/4 to 1/2 inch in size...glue is already attached inside the groove but as you say..to each his own.....you got the ball rolling for a problem with something like this....its a start to something great...and more ideas will follow... CLICK HERE TO GO TO yogitunes's LINK |
Post# 642834 , Reply# 9   11/30/2012 at 09:56 (4,164 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Don't you still have to take the front panel off when you clean it out? How do you keep the water from running everywhere.
The first time I cleaned my trap I was not prepared for the amount of water that ran out. Recently when a repairman was out (had to replace a pressure switch). He showed me how the pump will come out of the rubber mount and you can tilt it outside the frame to drain in a bucket or pan. (Mine is on a pedestal). I haven't ever found anything in the trap, but I checked it after washing the dog's rugs and it was clear. |
Post# 642874 , Reply# 11   11/30/2012 at 13:38 (4,164 days old) by applianceguy47 ()   |   | |
slide it under the front.
This whole thing is kinda... |
Post# 642875 , Reply# 12   11/30/2012 at 13:40 (4,164 days old) by applianceguy47 ()   |   | |
Loosen the filter |
Post# 642876 , Reply# 13   11/30/2012 at 13:40 (4,164 days old) by applianceguy47 ()   |   | |
I had to use a wrench to get it started. The rubber seal fits good. |
Post# 642877 , Reply# 14   11/30/2012 at 13:41 (4,164 days old) by applianceguy47 ()   |   | |
Let some of the water out, then replace the filter to stop the flow. |
Post# 642878 , Reply# 15   11/30/2012 at 13:43 (4,164 days old) by applianceguy47 ()   |   | |
This whole thing is kind of embarrassing, I post these regrettably, I... |
Post# 642879 , Reply# 16   11/30/2012 at 13:44 (4,164 days old) by applianceguy47 ()   |   | |
dump the first batch of water.
... really, its been a while since I cleaned this out. |
Post# 642880 , Reply# 17   11/30/2012 at 13:45 (4,164 days old) by applianceguy47 ()   |   | |
I slid it back under, and this time got it under the leg as a little bit of water escaped the tray.
Then start to remove the filter.
.... I really, I , I shouldn't really post these. It makes me look.... |
Post# 642881 , Reply# 18   11/30/2012 at 13:46 (4,164 days old) by applianceguy47 ()   |   | |
Use sponge to sop up extra water.
... I'm , O.K., you know what, this, it, this will be.... |
Post# 642882 , Reply# 19   11/30/2012 at 13:48 (4,164 days old) by applianceguy47 ()   |   | |
Post# 642883 , Reply# 20   11/30/2012 at 13:48 (4,164 days old) by applianceguy47 ()   |   | |
Post# 642884 , Reply# 21   11/30/2012 at 13:49 (4,164 days old) by applianceguy47 ()   |   | |
it's been a while... |
Post# 642885 , Reply# 22   11/30/2012 at 13:50 (4,164 days old) by applianceguy47 ()   |   | |
oh Dear... |
Post# 642886 , Reply# 23   11/30/2012 at 13:50 (4,164 days old) by applianceguy47 ()   |   | |
(nervous mittens romney laugh) |
Post# 642887 , Reply# 24   11/30/2012 at 13:52 (4,164 days old) by applianceguy47 ()   |   | |
... so the flow was a bit restricted with that and , I ...
Post# 642889 , Reply# 25   11/30/2012 at 13:53 (4,164 days old) by applianceguy47 ()   |   | |
...sometimes I forget stuff in my pockets, it's an old story. |
Post# 642890 , Reply# 26   11/30/2012 at 13:53 (4,164 days old) by applianceguy47 ()   |   | |
(sigh) ? |
Post# 642891 , Reply# 27   11/30/2012 at 13:55 (4,164 days old) by applianceguy47 ()   |   | |
OH COME ON.... Now what? |
Post# 642893 , Reply# 28   11/30/2012 at 13:55 (4,164 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Post# 642894 , Reply# 29   11/30/2012 at 13:56 (4,164 days old) by applianceguy47 ()   |   | |
Post# 642895 , Reply# 30   11/30/2012 at 13:57 (4,164 days old) by applianceguy47 ()   |   | |
Seriously ?
I've been looking for, ... ohhhh.
How gross. |
Post# 642896 , Reply# 31   11/30/2012 at 13:58 (4,164 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Post# 642897 , Reply# 32   11/30/2012 at 13:58 (4,164 days old) by applianceguy47 ()   |   | |
spray with some vinegar, normally I would let it sit or soak, but, its not really going to matter anyway. As long as the big stuff is off it. |
Post# 642898 , Reply# 33   11/30/2012 at 13:59 (4,164 days old) by applianceguy47 ()   |   | |
Post# 642899 , Reply# 34   11/30/2012 at 14:00 (4,164 days old) by applianceguy47 ()   |   | |
Wipe up any residual water. |
Post# 642900 , Reply# 35   11/30/2012 at 14:00 (4,164 days old) by applianceguy47 ()   |   | |
and any water that ran onto the panel bottom.
Post# 642901 , Reply# 36   11/30/2012 at 14:01 (4,164 days old) by applianceguy47 ()   |   | |
thats alot of water and it all stayed on the tray. |
Post# 642902 , Reply# 37   11/30/2012 at 14:02 (4,164 days old) by applianceguy47 ()   |   | |
Post# 642903 , Reply# 38   11/30/2012 at 14:03 (4,164 days old) by applianceguy47 ()   |   | |
reinstall filter.
Post# 642904 , Reply# 39   11/30/2012 at 14:04 (4,164 days old) by applianceguy47 ()   |   | |
Easy Peasy. |
Post# 642947 , Reply# 40   11/30/2012 at 16:32 (4,164 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 642997 , Reply# 41   11/30/2012 at 19:47 (4,164 days old) by Yogitunes (New Jersey)   |   | |
Post# 643033 , Reply# 42   11/30/2012 at 21:54 (4,164 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 643079 , Reply# 43   12/1/2012 at 01:07 (4,163 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 643124 , Reply# 44   12/1/2012 at 10:41 (4,163 days old) by logixx (Germany)   |   | |
