Thread Number: 43762
Kenmore Direct Drive Question |
Post# 643207 , Reply# 1   12/1/2012 at 15:08 (4,163 days old) by coldspot66 (Plymouth, Mass)   |   | |
Broken motor coupling. |
Post# 643208 , Reply# 2   12/1/2012 at 15:08 (4,163 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Most likely a broken motor coupler. Easy to fix! The coupler sits between the motor and the transmission. Remove the two clips holding the pump to the front of the motor, remove two clips holding the motor onto the transmission and bingo. Most times this can be done with just leaning the washer back and accessing the above from the bottom. The coupler will be two plastic wheels with three fingers each and a rubber wheel that sits between them.
RCD |
Post# 643209 , Reply# 3   12/1/2012 at 15:09 (4,163 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Does it still pump water out?
If so, 99% chance that the drive coupler between the motor and transmision broke. One of the more common breakdowns these machine have. 10 minute repair for a pro, 30 minutes for an amateur doing it for the first time. Part is inexpensive. CLICK HERE TO GO TO Kenmore71's LINK |
Post# 643210 , Reply# 4   12/1/2012 at 15:09 (4,163 days old) by Kenmore71 (Minneapolis, MN)   |   | |
