Thread Number: 43996
Kd- 20 strainers what gives ? |
Post# 646633   12/15/2012 at 10:45 (4,150 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 646671 , Reply# 1   12/15/2012 at 13:34 (4,150 days old) by qsd-dan (West)   |   | |
Take peek at the water line on your 20 and you'll have your answer :)
The KD-18 and older machines have a higher fill rate with a water line that's about a 1/2 inch from the very top of their screen mesh. The KD-19 and 20 machines (and newer) have a lower water fill rate with a water line that's just a hair higher than their screen mesh. |
Post# 646674 , Reply# 2   12/15/2012 at 13:49 (4,150 days old) by qsd-dan (West)   |   | |
Post# 646717 , Reply# 3   12/15/2012 at 16:35 (4,150 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 646963 , Reply# 6   12/16/2012 at 18:53 (4,148 days old) by qsd-dan (West)   |   | |
Post# 646983 , Reply# 7   12/16/2012 at 20:52 (4,148 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
The KDS-18 has two fill levels. The low fill level should be at top of vertical wall of strainer. Low fill level phases are pre-washes 1 & 2 and the final rinse. High water fill level should be 2" up the vertical plane of the strainer. 3rd pre-wash, main wash and rinses 1 & 2.
The 19 and 20 series also have two fill levels 7 & 9 quarts. |
Post# 647070 , Reply# 8   12/17/2012 at 07:15 (4,148 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
I don't know how far my machine fills, I think I have the cycle timing charts, I just got the SM &PM for the 17,18,19,20,21 machines. I just thought the all access design of the metal filter would return more water to the pump quicker. With the black filter in the machine definitely goes whoosh whoosh , with the all metal its more of a constant roar. The black one which came with the machine states in embossed letters on top that the heating element is NOT engaged in the drying cycle.
This post was last edited 12/17/2012 at 09:11 |
Post# 647085 , Reply# 9   12/17/2012 at 08:24 (4,148 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 647098 , Reply# 10   12/17/2012 at 09:17 (4,148 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
