Thread Number: 44046
Servis mk2.....some updates, and help needed... |
Post# 647438   12/18/2012 at 16:24 (4,146 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Hi All, so, the Servis finally had a timer, I just need to adapt the knob to the spline which is bigger....
So all I miss now it's the other 2 knobs, Mike is going to send me one...I hope I can find another one.... There is maybe a big problem though, since I had the timer working I could not wait to run some loads in it in these days, (I'd like to wait to have it "completed" before making a video to post here), well, tonight I was doing some laundry with it again, so transferred laundry in the spinner, ran the first spin after wash, all okay, so then I raised the lid to stop spinner and added water for soak filling and rinse spin, but got this bad surprise: trying to close the lid it didn't go down...I tried to push and lift the button but the lid just won't close, and spinner won't run of course, looks that the device got blocked, broken...who knows? I removed the back panel and tried to see how that device looks like....I removed it's screws (screwed on the top) one of the which had a wire twisted on it, it should be a red/hot wire (black and yellow) and looks it gives current to the internal thing...it's really weird that device and honestly I have no idea of how it does work nor how to remove it in full, it does have cilinder inside that would go up and down and or back and forth...not sure...will take a pic tomorrow with daylight...someone knows what could be wrong with it? How to fix it? Eventually how can I do to remove the top panel? I'm scared to do that though, because the boot in the spinner tub is very dry and could break very easily if I renmove it.... but them still available? That would be nice to replace it if posssible... Thank you in advance! Freddy |
Post# 649558 , Reply# 1   12/28/2012 at 14:58 (4,136 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Hi all, I have disassembled the top and removed the thing that holds the lids to check the internal mechanism, I could not fix it but at least now I can close the lid, I will just jump the wires to make spinner run, so it will run even with lid raised (I will just have to turn it off before opening), I made sure the mechanism keeps it closed during spin, heck it spins really fast!!! Will post some pics. |
Post# 649559 , Reply# 2   12/28/2012 at 15:12 (4,136 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 649560 , Reply# 3   12/28/2012 at 15:14 (4,136 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 649561 , Reply# 4   12/28/2012 at 15:15 (4,136 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 650388 , Reply# 5   1/1/2013 at 12:50 (4,132 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Re-assembling everything after gluing tub seal and internal lid seals with transparent silicone...... Wow! What a job join the worktop back! It took 40 mins! Hope also the front panel will not require as much as the last time, I needed the help of my sister and we spent 30 mins before get it perfectly framed, those rubber strips kept slipping and falling all the time.
Post# 650389 , Reply# 6   1/1/2013 at 13:07 (4,132 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Glad to see you like a challenge Freddy, the top is a real pain to get off and put back on, actually when you know what to do I`m told by the engineers its easy, but if you had seen me and the gang trying to get it off and then back on I was all ready for ditching it...LOl
With the top off check all the gaskets, these are what stops the water from spraying over the inside and shorting the electrics....those gaskets are non existant unless you have a donor machine so its crucial you keep it preserved, we used a spray silicone from a car parts place, spray on and rub it to re-supple the rubber parts, also the washer top gasket was starting to crack, if yours is the same rub some waterproof clear sealant onto it, then with the top back on it will seal well.. The spinner drum spins at 2,800rpm its very fast, is it smooth when running?, are the spin mounts good?, does it move around at all? What was the original problem with the lid? was the open lid lever broken? Glad to see you are getting stuck in, your postman should have the control knob with you shortly!! Mike |
Post# 650416 , Reply# 7   1/1/2013 at 15:13 (4,132 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Hi Mike, nice to hear from you! The spinner works enough smotthly, so it is almost 3000rpm, thanks for the info! The mounts looks fine, at least I believe so, I can bend the drum left and right but looks hard like it should be....it produce some vibrations for the first seconds, but then runs smoothly unless bad distribuited load occurs. Never heard it banging though. Thank you so much Mike for the knob, I'll let you know when it comes, now I miss just another one. Thank you for the great help! |
Post# 650539 , Reply# 8   1/2/2013 at 02:36 (4,132 days old) by keymatic (London / UK)   |   | |
Hi Freddy,
Hope you are well, and Happy New Year & all the best for 2013. Looks like that Servis is being a challenge, hope you are getting there one way or another. How did you get on with timer ? Did you manage to get it fixed ? I went down the garage yesterday and had a good rumage around. I think I have found a pump knob, but it hasn't got the chrome inset, also i think I have found a timer !! They were made by Smith's of Cricklewood London. I will confirm when I have had a better look. Anyway catch you soon Keith |
Post# 650609 , Reply# 9   1/2/2013 at 12:46 (4,131 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Thank you Keith! Same to you! Happy 2013 to all! future! I want this machine up and running! Yes even the broken timers I've here says they're made by Smiths Clocks Ltd. I'm here trying to get that damn front panel back in place, it is about an hour that I'm trying but no success...... I guess that if I hadn't my aching ribs due to my strong cough it would be easier, now they hurts so much I had to stop..... now I'm taking some rest, will have dinner and try again later, maybe a dish of pasta will give me some forces! LOL Will keep you posted. This post was last edited 01/02/2013 at 13:22 |
Post# 650710 , Reply# 10   1/3/2013 at 02:31 (4,131 days old) by buzywoman ()   |   | |
Very beautifull twin tub. Do you have a year of made ? |
Post# 650783 , Reply# 11   1/3/2013 at 13:13 (4,130 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Hi all, everything assembled finally! After others 30 minutes of pains! The Servis is ready back for a wash tonight. (Sorry for the messy background) |
Post# 650787 , Reply# 12   1/3/2013 at 13:22 (4,130 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Buzywoman: Mine is a 1964 model, it was told me so from the Miss/Lady? Who sold and shipped it to me, also removing the top I found a stamp on the bottom it was half deleted it stated something looking like a date ending with "964" so all makes think that it is a 1964 model. |
Post# 650815 , Reply# 13   1/3/2013 at 16:26 (4,130 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Bad luck is fòllowing me with this machine! Where can I find one that fits the machine? Thank you! CLICK HERE TO GO TO kenmoreguy89's LINK on eBay This post was last edited 01/03/2013 at 16:47 |
Post# 651292 , Reply# 14   1/5/2013 at 17:47 (4,128 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Someone must be doing some kind of hodoo to me or my machine.... Paid it 30 euros! |
Post# 651297 , Reply# 15   1/5/2013 at 18:11 (4,128 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
P.S |
Post# 651299 , Reply# 16   1/5/2013 at 18:17 (4,128 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
This would be almost like the original...it is 16mm though! :( CLICK HERE TO GO TO kenmoreguy89's LINK on eBay |
Post# 651814 , Reply# 17   1/8/2013 at 06:38 (4,125 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 651815 , Reply# 18   1/8/2013 at 06:40 (4,125 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 651816 , Reply# 19   1/8/2013 at 06:41 (4,125 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 651867 , Reply# 21   1/8/2013 at 14:35 (4,125 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Hi fido unfortunately not... |
Post# 651985 , Reply# 22   1/9/2013 at 01:22 (4,125 days old) by fido ()   |   | |
Ah, I didn't realise it was a new timer, I had assumed it was another old one from a Servis. |
Post# 652008 , Reply# 23   1/9/2013 at 07:33 (4,124 days old) by keymatic (London / UK)   |   | |
Hi Freddy,
We will get this machine going one way or another !! LOL Here is the Timer & knob, I think they should be indentical to what you have, apart from this timer does work...well saying that i haven't tested it, but it certainly did when it was taken off them machine, and it ticks nicely :) As i mentioned before the knob doesn't have the chrome insert, tried looking everywhere, but to no avail. Sent me your address, I will send you a private email as well. Regards Keith |
Post# 652247 , Reply# 24   1/10/2013 at 12:29 (4,123 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Thank you so much Keith! I'm going to send you an email now, thank you! Yes the timer looks identical in shape, only difference my original one does not have that sticker but of course is the same thing, You all guys are so kind and helping me alot, you make me so happy, thank you infinitely! |
Post# 652250 , Reply# 25   1/10/2013 at 12:38 (4,123 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 652428 , Reply# 26   1/11/2013 at 08:56 (4,122 days old) by keymatic (London / UK)   |   | |
Hi Freddy,
No Probs, I glad i can help you out...I will package it up and send it off next week. I got your address through. The wires aren'nt marked but there are only two, so hopefully you will get them round the right way. Your machine was the first twin tub i obtained, that was nearly 20years ago..I really liked though, especially the "Deep Rinse" Anyway, I will gett the timer & knob off to you early next week :) Cheers Keith |
