Thread Number: 44286
Full flow solenoid - has anyone tried this? |
Post# 650828 , Reply# 1   1/3/2013 at 17:39 (4,131 days old) by Yogitunes (New Jersey)   |   | |
well, it would probably allow more water, but its not a FULL flow valve, like a ball valve opens to the full opening of the pipe its connected to.....
and they probably have other versions, but the one in the link is for 12v DC power... possible they have one very close to an actual washers valve....or even a dual input HOT/COLD.....might be interesting.... |
Post# 650859 , Reply# 2   1/3/2013 at 21:30 (4,131 days old) by Unimatic1140 (Minneapolis)   |   | |
and took out the restrictor
Hello and welcome, I'm curious where this restictor was that you took out? In vintage automatic washer water valves, the water flow restrictor is located right under the valve outlet to the wash tub. I've taken those out many times to increase the water flow and there isn't a way for taking that out to affect the valves from operating. Are you sure you took out the flow restrictor and not something else? |
