Thread Number: 44855
leaking Maytag washer model a207 |
Post# 658006   2/4/2013 at 09:58 (4,098 days old) by doris ()   |   | |
could someone plz provide instructions on how to open panel/s in order to get at inside of washer ? |
Post# 658009 , Reply# 1   2/4/2013 at 10:14 (4,098 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Getting into a Maytag is easy.
On the front panel of the machine, close to the bottom, there is a ridge, and then the panel has an area at the very bottom that is recessed. Under the ridge, there are two screws. Remove the screws, and grasp the front panel at the bottom. Pull it outward and swing the panel towards you. At the top of the panel, the panel is held by two clip assemblies that will let go all by themselves if you will just keep swinging the panel outward and toward you. Reassembly involves seating the top edge of the panel back on the clips, swinging the bottom of the panel back into place, and re-installing the screws. |
Post# 658324 , Reply# 2   2/5/2013 at 19:25 (4,097 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 658506 , Reply# 3   2/6/2013 at 16:27 (4,096 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 658523 , Reply# 4   2/6/2013 at 17:20 (4,096 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
