Thread Number: 45267
1960 Maytag Dryer |
Post# 663122   2/28/2013 at 19:05 (4,074 days old) by bendixmark (Winchester Mass)   |   | |
This nice dryer is at Grays Appliance in Melrose Mass.Call and ask for Brian.I dont think they want much for it just want it to have a home instead of being crushed.781 665 2671 |
Post# 663123 , Reply# 1   2/28/2013 at 19:08 (4,074 days old) by bendixmark (Winchester Mass)   |   | |
Shot of the control panel. |
Post# 663124 , Reply# 2   2/28/2013 at 19:10 (4,074 days old) by bendixmark (Winchester Mass)   |   | |
Front and drum |
Post# 663143 , Reply# 3   2/28/2013 at 20:37 (4,074 days old) by dnastrau (Lords Valley, PA)   |   | |
A quick wipe down and that will look almost new. Is that a "Highlander" dryer? |
Post# 663212 , Reply# 4   3/1/2013 at 05:56 (4,074 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Oh, yes, it is a Highlander dryer. Note the single panel door with the plug for the drum opening and the galvanized, not porcelain drum. Maytag made it very obvious that the Highlanders were the cheaper models in the line. |
Post# 663356 , Reply# 5   3/1/2013 at 20:15 (4,073 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 663377 , Reply# 7   3/1/2013 at 22:44 (4,073 days old) by badgerdx ()   |   | |
It might be a lower end model, but I love the cleanliness of the design. Contemporary washers/dryers make me gag: They look so cheap and plastic and ridiculously overly complex. |
Post# 663421 , Reply# 8   3/2/2013 at 05:08 (4,073 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The mechanical and electrical that most often wear out on HOH dryers are, heating element and complete heater shroud assembly, front drum seal and then you motor pulley, motor, belts, idler pulley and bearings and shaft, blower wheel and bearings, main drum bearings and shaft and even the complete base pan and support will fit any HOH dryer built through 1965.
About the only functional parts that this Highlander would not provide to fix a TOL pre 06 HOH dryer would be the rubber door seal and the electronic controls. |
Post# 663464 , Reply# 10   3/2/2013 at 11:58 (4,073 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 668368 , Reply# 16   3/25/2013 at 19:05 (4,050 days old) by bendixmark (Winchester Mass)   |   | |
You thanked everyone but me who took the pictures and posted the dryer in the first place. |
Post# 668388 , Reply# 17   3/25/2013 at 20:52 (4,049 days old) by easy (Boston, Mass)   |   | |
Mea culpa - you're absolutely right, I should have thanked you for your role in helping me to get this machine. |
Post# 668594 , Reply# 18   3/26/2013 at 20:24 (4,048 days old) by bendixmark (Winchester Mass)   |   | |
I will keep an eye out for the matching washer.So glad you got the dryer it sure is sweet. |
