Thread Number: 45605
HE3t Click and Rattle noise |
Post# 668870 , Reply# 2   3/28/2013 at 11:39 (4,052 days old) by aquarius1984 (Planet earth)   |   | |
Before the scaremonger lot chime in just check its not something like a lost bra wire trapped under the tub or something that might not cause the noise when the drums rotating one way but does the other way.
Piece of wire, a coin, plastic, all can float around in water and make very little noise but when the tub drains and empties and a certain tub speed can cause the foreign object to move from its usual hiding place and cause a noise. Take the top off the machine and shine a torch into the drum while rotating it should enable you to see anything that is causing the issue first. You might have to stick your head inside the drum to see clearly. - much easier than stripping it down. |
Post# 668997 , Reply# 4   3/29/2013 at 02:11 (4,051 days old) by Limey ()   |   | |
Here is what one machine with a fractured spider sounded like CLICK HERE TO GO TO Limey's LINK |
Post# 670131 , Reply# 5   4/3/2013 at 01:38 (4,046 days old) by laundromat (Hilo, Hawaii)   |   | |
I have a similar model (Whirlpool Duet) and there is a button catcher connected on the pump. You have to remove the base panel right under the door.There are bolts to remove in order to access the device. Once there, take a bowl or small bucket to catch reserved water and place it just under the cup. Unscrew the coverand look inside for any loose items. They usually fall right out.Remove any lint and rescrew the cover on. Move it to meet the green dot located on the cylinder.You need to do this periodicly especially if you don't check pockets before loading.
