Thread Number: 45782
Speed Queen Wringer - pump won't work - need some help |
Post# 669689 , Reply# 1   4/1/2013 at 16:17 (4,042 days old) by Yogitunes (New Jersey)   |   | |
Post# 669781 , Reply# 3   4/1/2013 at 23:24 (4,042 days old) by stan (Napa CA)   |   | |
I wouldn't think it's electric, except that the switch for the pump seems kinda puiny for it to be all machnical ? ?
Look and see if there is any wires going to the switch to the pump motor! Never looked under a Speed Queens skirt (maytag only) LOL Let us know, and take a pic for us if you can. Hi Larry! How's Bessie Mae ? |
Post# 670021 , Reply# 5   4/2/2013 at 18:11 (4,041 days old) by mickeyd (Hamburg NY)   |   | |
It works like most: the switch moves the pump into the pulley, but the SQ pump, although slow, is a dream boat because it's held together with a no-tool-needed hand screw and a clamp.
Just your thumb and forefinger will release the screw, then slide the clamp off the rims and OPEN SESAME. You'll see at once whatever gunk is plugging up the works. The impeller is joined to the upper half of the pump case. But first, before you take anything apart, make sure you've got contact between the pump and pulley. This is easy enough to see when you go down and under the grand old gal. And then do what Gary says. He 's got many wringers and lots of experience. Thumbscrew as the last resort. |
Post# 670075 , Reply# 7   4/2/2013 at 19:55 (4,041 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
Could be that any lubricants on the moving parts associated with the pump may have dried out and become too stiff to move from sitting too long. I've seen that happen before too. Just clean off the old lube and apply new to correct the problem. BTW, that is a VERY nice looking washer. |
Post# 670094 , Reply# 8   4/2/2013 at 21:17 (4,041 days old) by bradross (New Westminster, BC., Canada)   |   | |
Post# 670097 , Reply# 9   4/2/2013 at 21:42 (4,041 days old) by stan (Napa CA)   |   | |
