Thread Number: 45828
speed queen transmission |
Post# 670300 , Reply# 1   4/3/2013 at 17:56 (4,052 days old) by Epixstar128 (toledo)   |   | |
can you repair or fix these leaking transmissions? |
Post# 670407 , Reply# 2   4/4/2013 at 07:58 (4,051 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I all depends on many other factors that you did not supply such as, are you doing it yourself? , can you do heavy repairs?, Are you really wedded to this washer?, And their many more questions, but in general I would not attempt repair of this washer unless your machine is less than ten years old in which you may be able to get a free replacement transmission. |
Post# 670418 , Reply# 3   4/4/2013 at 08:44 (4,051 days old) by BrianL (Saddle Brook, New Jersey)   |   | |
If you do decide to take on a repair, which can be a great rewarding experience, you will find many helpful members here willing to help you get your machine back in perfect running shape.
If for some reason you decide you want to part with it, I'm sure there would be someone else interested in the machine for parts or repair. Either way, as John had stated, a little more information would probably be helpful. Sometimes a picture doesn't hurt either. Best of luck! |
Post# 670425 , Reply# 4   4/4/2013 at 10:37 (4,051 days old) by Epixstar128 (toledo)   |   | |
The oil was comming from under the white hub in the Center of the picture |
Post# 670426 , Reply# 5   4/4/2013 at 10:40 (4,051 days old) by Epixstar128 (toledo)   |   | |
Pic |
Post# 670487 , Reply# 6   4/4/2013 at 17:50 (4,051 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 670538 , Reply# 7   4/4/2013 at 22:05 (4,051 days old) by Epixstar128 (toledo)   |   | |
That sucks i think the seller knew about mine the Kinda shady but hey that's life. I found a washer Just like it on craigslist for 100 bucks gonna try to Get it |
Post# 670952 , Reply# 8   4/6/2013 at 20:43 (4,049 days old) by Epixstar128 (toledo)   |   | |
i went out and got a new cheap washer at home depot. I plan on taking this speed queen apart and trying to just replace the seals in the transmission.I cant get the white center hub off any tips on how to get it off. |
Post# 671095 , Reply# 9   4/7/2013 at 13:09 (4,048 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 671172 , Reply# 10   4/7/2013 at 17:46 (4,048 days old) by Blackstone (Springfield, Massachusetts)   |   | |
