Thread Number: 45888
Finally Ordered Our Speed Queen's !!! |
Post# 671004 , Reply# 2   4/7/2013 at 06:21 (4,037 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 671031 , Reply# 3   4/7/2013 at 10:14 (4,037 days old) by teknikleespekng ()   |   | |
Enjoy your new machines! |
Post# 671052 , Reply# 4   4/7/2013 at 10:48 (4,037 days old) by billiedyer1954 (Ohio, USA)   |   | |
you should get to the second or third level of holes without raising the water level. I raised mine to the first row of holes. |
Post# 671231 , Reply# 6   4/7/2013 at 21:28 (4,036 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yay, I am sure you will enjoy these machines, as a SQ dealer I think you will find the water level very good as it comes from from the factory, I end up turning up the WL in only about 1 in 10 machines we deliver and install. The hot setting is all hot, but when set on warm 70% comes from the cold side and only 30% comes from the hot side, so unless your hot water is really hot or your cold water is not too cold you may find the warm setting gives you a cooler wash temperature than you like, this can be dealt with if you like. |
Post# 671669 , Reply# 7   4/9/2013 at 18:44 (4,035 days old) by aimeemarie12 ()   |   | |
I have only added water to mine a few times. You may find it is not necessary. |
Post# 673045 , Reply# 9   4/15/2013 at 20:40 (4,028 days old) by danorob1 ()   |   | |
Next The Old Dryer... |
Post# 673047 , Reply# 10   4/15/2013 at 20:41 (4,028 days old) by danorob1 ()   |   | |
The New Washer Carton - Built With Pride - (Actually it was nice to buy something made in the USA) |
Post# 673048 , Reply# 11   4/15/2013 at 20:42 (4,028 days old) by danorob1 ()   |   | |
The Dryer Carton - Also Made with Pride !!! |
Post# 673049 , Reply# 12   4/15/2013 at 20:43 (4,028 days old) by danorob1 ()   |   | |
Installed New 1/4 Turn Water shut off valves... I Like everything to be new - Plus I wanted quick turn valves.... |
Post# 673050 , Reply# 13   4/15/2013 at 20:45 (4,028 days old) by danorob1 ()   |   | |
Plus a nice new 4-prong outlet to replace the old three prong version ( I never understood why they installed a 3-prong anyway since they used 4-conductor cable !!!) |
Post# 673051 , Reply# 14   4/15/2013 at 20:46 (4,028 days old) by danorob1 ()   |   | |
And now...... The Newest Additions !!!!!!! The make a handsome couple.... |
Post# 673052 , Reply# 15   4/15/2013 at 20:47 (4,028 days old) by danorob1 ()   |   | |
The Washer Panel.... |
Post# 673053 , Reply# 16   4/15/2013 at 20:48 (4,028 days old) by danorob1 ()   |   | |
The Dryer Panel... |
Post# 673054 , Reply# 17   4/15/2013 at 20:49 (4,028 days old) by danorob1 ()   |   | |
The First Fill !!!!! (Yes I dumped in water to the bottom of the tub !!!) |
Post# 673055 , Reply# 18   4/15/2013 at 20:51 (4,028 days old) by danorob1 ()   |   | |
Inside of dryer.... I love the fact that clothes do not get stuck between the baffles and the fron or rear of the drum like they did in the Frigidaire... Speed Queen was smart enough to angle the ends of the baffles... |
Post# 673057 , Reply# 19   4/15/2013 at 20:56 (4,028 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 673060 , Reply# 21   4/15/2013 at 21:04 (4,028 days old) by danorob1 ()   |   | |
So I just noticed looking at the pictures in the posting of the dryer panel that it says "lifetime Interior" on the front of the panel... What the hell does that mean ??? It is warrantied forever ??? |
Post# 673102 , Reply# 22   4/16/2013 at 02:38 (4,028 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
I believe they mean that the stainless steel tub will last the life of the machine. No tub rusting there. And SQ used to advertise that the more you use your Speed Queen the softer the surface of the wash basket will be. |
Post# 681320 , Reply# 24   5/28/2013 at 06:33 (3,986 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You should have no problem with leaks by doing what you have done.
To raise the top you first remove the two screws at the bottom of the front panel and lift it away and off the washer, then you will see two more screws at the top that hold the washer top to the sides of the cabinet, once these are removed the top can be lifted [ it is hinged at the rear of the washer ]
Hope you enjoy your new washer, I feel that it is a much studier and better performing machine than the WCI-Frigidaire you had before, John. |
Post# 681344 , Reply# 25   5/28/2013 at 09:56 (3,986 days old) by drewz (Alexandria, Virginia)   |   | |
Post# 681474 , Reply# 27   5/29/2013 at 05:47 (3,985 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
