Thread Number: 46048
Rollermatic parts |
Post# 673017 , Reply# 1   4/15/2013 at 19:33 (4,028 days old) by marty (Central Point, Oregon)   |   | |
Also does anyone know the part number for the nut? Thanks! Marty |
Post# 673065 , Reply# 2   4/15/2013 at 21:28 (4,028 days old) by PhilR (Quebec Canada)   |   | |
Post# 673070 , Reply# 3   4/15/2013 at 21:57 (4,028 days old) by marty (Central Point, Oregon)   |   | |
Thanks Phil! Yes it is the turquoise set I'm going through it to prevent future problems. I got the agitator nut off no problem, but the tub nut was hell! Thanks! Marty |
Post# 673073 , Reply# 4   4/15/2013 at 22:26 (4,028 days old) by PhilR (Quebec Canada)   |   | |
Why did you remove the tub nut?
From your description, I was thinking you were referring to the pulsator cone nut. There's the large "sombrero" nut that holds the plastic cones of the agitator over the pulsator. But on most washers with this agitator, there's a nut with only the top part that's threaded that holds the lower cone (the rubber pulsator) in place. I think the 1965 parts manuals don't show it as it was added after the beginning of the production of this agitator. I don't know exactly when but I can tell you that most of the washers that had their agitators replaced had it and later production (I'm thinking somewhere during 1965) had it too.
The picture shows it. Is it the nut you're talking about? |
Post# 673075 , Reply# 5   4/15/2013 at 22:31 (4,028 days old) by marty (Central Point, Oregon)   |   | |
Phil, No that is not the nut. I took the tub nut off, so I could pull the inner tub. I wanted to clean, and inspect the outer tub. Thanks |
Post# 673078 , Reply# 6   4/15/2013 at 22:47 (4,027 days old) by PhilR (Quebec Canada)   |   | |
