Thread Number: 46226
Washer won't empty or spin |
Post# 675550 , Reply# 2   4/25/2013 at 23:15 (4,018 days old) by rcb151 ()   |   | |
Nothing works when it gets to the spin cycle. It just stops. Well, the timer seems to continue because after the first spin (it doesn't spin) it agitates again. But no strange sounds at any time. |
Post# 675552 , Reply# 3   4/25/2013 at 23:18 (4,018 days old) by stan (Napa CA)   |   | |
Post# 675582 , Reply# 4   4/26/2013 at 07:06 (4,018 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 675959 , Reply# 6   4/28/2013 at 00:32 (4,016 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
The timer motor contacts are the first to go, they carry the highest load and switch the most. The main contact (knob in/out) actually carries the entire load but it switches much less often than the motor contacts, only once per complete cycle.
Since it is a reversing machine there are 3 motor contact sets. Either start or run has to be reversed relative to the other one. (You may already know all this.) So there are 3 ways the motor contacts can fail. If the non-reversing contact fails the machine will not agitate or spin, so that lets that out in this case. However, if any of the 3 contacts fail, the motor will make a humming/growling sound briefly before it trips on overtemp. And you don't observe this. Nor do you observe the motor running while simply not producing any motion. Summing these observations--and I should say I am not a Norge expert never having owned or worked on one--the most likely suspect becomes the lid switch. UNLESS lifting the lid also stops agitation. Some machines do (Maytag), some don't. If your lid stops agitation, like the broadcast support engineers used to tell me when I described all the symptoms and checks and they were still stumped, "yep, you've got a problem alright". |
