Thread Number: 46706
Info on the ge topload washer with power rinse with its matching dryer |
Post# 680652   5/23/2013 at 10:14 (3,991 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
hello to all aw members as you know my duet set washer and dryers days are number as this summer the set i have will be 10 years old and i think the dryer is already on its las lengh so for my next set i am considering buying the ge topload washer with the power rinse option do not SUGGEST A FRONT LOAD WASHER i do not went to buy a front load washer i did not like the duet washer since the first day it was delivered back in 2004 i am more the top load kind since i only wash using cold water so for me having a water heater in a washer is not needed since the only cycle i use are normal perm press for shirt and sometime the gentle cycle and also the advantage of having a top load washer for me is if i have to soak something all night i will be able to do so also included is a pic of the set all info welcome thank you and i repeat do not suggest me a front load washer as a front load do not fit my needs.
Post# 680669 , Reply# 1   5/23/2013 at 14:19 (3,991 days old) by laundromat (Hilo, Hawaii)   |   | |
It's your choice but I highly recommend the service contract. I see more of these and the newer Whirlpool top loading agitator washers in the scrap pile at Lowes and Home Depot. They easily rust and the last newer models of GEs I worked on had to have the motor and the motherboard replaced. Over $300!!!
Post# 680675 , Reply# 2   5/23/2013 at 14:50 (3,991 days old) by golittlesport (California)   |   | |
..."lightning-quick" spin speed of 630 rpm? I don't think one could find a slower spin speed if one tried.
One thing that jumped out at me is that the dryer capacity (6.0) does not seem large enough for the washer's capacity (4.5). The Frigidaire dryer that stacked on top of their 3.1 cf front load washer was 5.8, and people thought that was too small. |
Post# 680684 , Reply# 3   5/23/2013 at 15:38 (3,991 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 680703 , Reply# 5   5/23/2013 at 17:57 (3,991 days old) by aladude ()   |   | |
Post# 680720 , Reply# 6   5/23/2013 at 19:44 (3,991 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 680778 , Reply# 7   5/24/2013 at 07:25 (3,990 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
I only can recomend (even through it is quiet expensive and a frontloader): BUY A MIELE :) |
Post# 680809 , Reply# 8   5/24/2013 at 11:19 (3,990 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
read my post above i said no front loader for me a front load washer is not convinient thats what i have right now and i hate ted it since 2004 for 1 thing i do not need long cycles wash time 1 second i do not need fancy cycles other than normal perm press for shirts and gentle delicate cycle and also sometime there is stuff i may need to soak all night and also i will repeat again do not suggest a front load washer i will never buy a front load washer again for me a top load washer is more convinient.
Post# 680814 , Reply# 10   5/24/2013 at 12:58 (3,990 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 680854 , Reply# 11   5/24/2013 at 19:06 (3,990 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 680927 , Reply# 12   5/25/2013 at 07:57 (3,989 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 680928 , Reply# 13   5/25/2013 at 08:08 (3,989 days old) by ozzie908 (Lincoln UK)   |   | |
and buy a new plastic twin tub they spin about 1400 rpm and you can fill it with cold water to save money. Personally if I wanted to use just cold water and slow spin I would go to the nearest stream with a rock and do my laundry there as it would get just as clean and germ free and I can wring water out by hand and save even more !!
Austin |
Post# 680949 , Reply# 14   5/25/2013 at 11:37 (3,989 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 680954 , Reply# 15   5/25/2013 at 12:04 (3,989 days old) by DADoES (TX, U.S. of A.)   |   | |
This is what happens with exclusive cold water washing -- My sister, has a Maytag A512, almost 30 years old. They wash everything in cold water, for reason as she explained to me "So our t-shirts don't shrink & fade." I assume there's not much sorting happening, either ... which facilitates their teenage (well, not now, but teenage or maybe even preteen back when it started) son doing some of the washing without having to deal with sorting. The machine reeks with a musty odor. There's a Sears storefront in their town, so I had her fetch an orange box of Sears detergent for me a while ago during a big sale. She also bought a box. She reported that it cleaned very well regards to getting out stains but the clothes didn't smell clean. The detergent has a mild chemical-type scent, no perfuming, so the clothes don't get perfumed with "fresh breeze" or "tropical ocean" or "mango whango" or whatever ... instead they're left with the machine-musty odor. A few weeks ago she reported finding some detergent or other that at least makes her hubby's work-out sweats smell better. Icky to think of the residue hiding in that A512 after literally years of cold-only washing. |
Post# 680998 , Reply# 17   5/25/2013 at 18:11 (3,989 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
anyway once every 3 months i plan on using afresh water cleaner to clean the machine and i thank you for the info if you have a good topload to recomend, do you think i should look into the new belt drive whirlpool top load washer with agitator, even do i do not went to have a lid lock but right now i am only gathering info as my actual set this summer will be going on the 10 year and the dryer is going on its last leg i think it might be the humid factor and the heating, element starting to fail i am no expert but when i have a heavy load to dry i sometime notice that clothes stays wet so that force me to restart the dryer and i have it set on high heat to make sure clothes are dry. Bu i will look into the huebesch washer as well.
Post# 681090 , Reply# 20   5/26/2013 at 10:06 (3,988 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
thank you do you know whitch stores in my province for the town i live in sell huebesch top load washer, because this model i fine intressting and there the advantage of the mini water level that i like. And i would buy the matching dryer of course since i am the one doing the laundry for me and my mom.
Post# 681185 , Reply# 21   5/27/2013 at 03:01 (3,987 days old) by qualin (Canada)   |   | |
I don't know what province or city you live in. Your location just says "Canada". Why not just use the Dealer Locator on the site? CLICK HERE TO GO TO qualin's LINK |
Post# 681197 , Reply# 22   5/27/2013 at 06:34 (3,987 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 681216 , Reply# 23   5/27/2013 at 12:10 (3,987 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Washer111,
for your info i will not botter to pay for a repair on my actual dryer if like you said its clog its clog since 2005 since when i had an old dryer vent a bird went in the dryer it died inside even do i tryed starting the dryer to push it out, it must be what cloging it but like i said i will not bother to pay for a repair since for me the better option is replacing it, and qualin in my town this is the store that sell huebesh washer dryer set. Corbeil Électroménagers 1563,BOUL.DES PROMENADES ST-HUBERT, QC J3Y 5K2 View Map Phone: 450-676-8861 Fax: 450-676-6402 Email: info@corbeilelectro.com URL: www.corbeilelectro.com... |
Post# 681220 , Reply# 24   5/27/2013 at 12:44 (3,987 days old) by Hoover1100 (U.K.)   |   | |
You mean there has been a dead bird stuck in your dryer vent for 8 years!? I bet that smelled lovely... *shudders* |
Post# 681232 , Reply# 25   5/27/2013 at 15:24 (3,987 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 683904 , Reply# 26   6/14/2013 at 16:08 (3,969 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
i would like to say a big thank you to all aw members as i think my mind is made up here are my choice by order
1-huebsch top load washer model zwn432 with matching dryer (depending on price) 2 the ge topload washer with power rinse 3- the new kenmore whirlpool made topload with lid lock with agitator 4-the new whirlpool topload load washer with agitator with there matching dryers |
