Thread Number: 47137
Maytag washer A410 |
Post# 685104 , Reply# 1   6/22/2013 at 15:03 (3,960 days old) by mrb627 (Buford, GA)   |   | |
Post# 685140 , Reply# 2   6/22/2013 at 22:07 (3,960 days old) by patti (California)   |   | |
Hi Malcolm, I have spent a fair amount on it this last year. Now during the wash cycle it stops and I hear clicking. If I shut it off and wait a while it will resume washing. It doesn't do this every time. Thanks. |
Post# 685141 , Reply# 3   6/22/2013 at 22:11 (3,960 days old) by patti (California)   |   | |
Also during the wash cycle the motor changes and makes an awful noise. I got a rebuilt motor last year. My repairman thought it might be a good idea to upgrade to a slightly newer machine. |
Post# 685148 , Reply# 4   6/22/2013 at 23:12 (3,960 days old) by DigAPony ()   |   | |
The A512 has the sliding infinite water lever selector, along with the A612 and A712, but the A512 is more commonly available used. |
Post# 685157 , Reply# 5   6/23/2013 at 03:11 (3,959 days old) by pdub (Portland, Oregon)   |   | |
The clicking sounds like the motor overheating and cutting out. This could be due to improper belt tension, worn belts, or motor slide needing cleaning and lubrication. It also could be more complicated like the transmission putting too much load on the motor but I would check out the belts and make sure the motor moves freely on its slide first. Also make sure there isn't an oil leak underneath that could be gumming up the belts.
Best of luck. Patrick |
Post# 685195 , Reply# 6   6/23/2013 at 10:59 (3,959 days old) by patti (California)   |   | |
> Thank you, Patrick. That was my first thought too. My repairman thought I could buy an A512 for what it might cost me to fix this one. He also said the 512 was a better machine than my 410. What do you think? |
Post# 685211 , Reply# 7   6/23/2013 at 12:48 (3,959 days old) by patti (California)   |   | |
The A512 has the sliding infinite water lever selector, along with the A612 and A712, but the A512 is more commonly available used. Dig A Pony, can you tell me the differences between the 512, 612, and 712? Is one better than another? Thanks! |
Post# 685226 , Reply# 8   6/23/2013 at 13:53 (3,959 days old) by Yogitunes (New Jersey)   |   | |
I don't know that one Maytag would be better than any other....for the most part, they are all the same internals, give or take a newton or orbital tranny......
the only difference between models would be capacity, cycles/options, and speeds.... a BOL unit is not built any less than a TOL unit as far as internals, especially when it comes to a true Maytag.... this link from one of our members will give you a good idea of features from each model in general.... CLICK HERE TO GO TO Yogitunes's LINK |
Post# 685283 , Reply# 9   6/23/2013 at 20:34 (3,959 days old) by patti (California)   |   | |
Thank you so much for the link! |
Post# 685536 , Reply# 14   6/25/2013 at 09:59 (3,957 days old) by patti (California)   |   | |
I am in the San Francisco Bay area. I would love it if there are local Maytag fans that could keep an eye out for me. Thanks! |
Post# 687965 , Reply# 18   7/8/2013 at 13:11 (3,944 days old) by patti (California)   |   | |
My repairman was here this morning. He says the problem is electrical. The motor overheats and shuts off. He did not check the belts or anything else. Shouldn't that have been done first? What do you think? |
Post# 689416 , Reply# 21   7/14/2013 at 19:49 (3,938 days old) by Patti (California)   |   | |
I can stop that noise by changing the button from Gentle/Fast to Gentle/Slow. This is when it is agitating. Any ideas? |
