Thread Number: 47209
Wear that Crown King |
Post# 686014   6/27/2013 at 13:57 (3,955 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 686018 , Reply# 1   6/27/2013 at 14:29 (3,955 days old) by rp2813 (Sannazay)   |   | |
Post# 686021 , Reply# 2   6/27/2013 at 14:44 (3,955 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 686037 , Reply# 3   6/27/2013 at 16:39 (3,955 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 686097 , Reply# 4   6/27/2013 at 23:26 (3,955 days old) by redcarpetdrew (Fairfield, CA)   |   | |
My father in law had an older Waste King with that upper washarm supply tube that kept breaking off. Never one to waste anything (read couldn't throw anything away...), he found that tube to make an excellent paper towel holder for his shop, etc. Most likely a better use than what it was intended for in the first place and definitely produced better cleaning results than when it was in the machine...
RCD |
Post# 686230 , Reply# 5   6/29/2013 at 00:19 (3,954 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 686495 , Reply# 6   6/30/2013 at 16:13 (3,952 days old) by william637 (Damp pants? Not a chance. )   |   | |
In this instance, it would be me. I have the older brother of this machine (without the steam) which I got just because I didn't think I would ever be lucky enough to find one of these. I paid for it today and will drive up to New York in two weeks to collect it.
I know everyone has talked about how crappy these machines really are, but I have always been fascinated with them since I saw an ad for it in a magazine as a child. It's a sexy machine...and who says sexy has to have substance? Britney Spears has done well for herself after all... |
Post# 686497 , Reply# 7   6/30/2013 at 16:24 (3,952 days old) by rberryiii3 (Palm Springs, California)   |   | |
I have always loved these machines( but then ignorance is bliss) let me know how it works out. Rob |
Post# 686585 , Reply# 8   6/30/2013 at 23:52 (3,952 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 686657 , Reply# 9   7/1/2013 at 12:30 (3,951 days old) by william637 (Damp pants? Not a chance. )   |   | |
Post# 686678 , Reply# 10   7/1/2013 at 15:07 (3,951 days old) by rp2813 (Sannazay)   |   | |
Yes, as the capital "S" above indicates.
This clone pictured below had Nate and I spellbound from its looks to the point of overpaying for it, fashioning new stainless-look panels for it, and installing it.
The spell wore off as the spotting and filming went on. It was bad enough to make it onto Nate's "Machines of Ill Repute" short list that he posted some time ago.
Mark, if you can get the WK to turn out clean dishes, in spite of the steam option -- not as a result of it, do be sure and let us know how you did it. I might still have my Thermador if it performed well and was quiet about doing so, but the lower rack accommodation for the upper spray arm provided the third strike, so out it went. |
Post# 686687 , Reply# 11   7/1/2013 at 15:44 (3,951 days old) by william637 (Damp pants? Not a chance. )   |   | |
I read the post you referred to sometime back. It is going to be interesting to see what happens when I actually put dishes in it. Of course, knowing me, it will just be placed in the rack in the basement, hooked up to water, and run occasionally just to listen to it.
I have several cool machines in the basement, some of which I have talked about bringing up to the kitchen, but it has yet to happen. Mainly because I have two dishwashers in the kitchen and I want them to match. I don't have two matching dishwashers in the basement (yet). Several weeks ago I just had to try out the reverse rack jenn-air so I took a few bus pans of dishes down to the basement. It was a fun experiment, until I had to drag everything back up the stairs. But the way everyone talks about these steam machine dishwashers...I'm going to have to give it a try.... |
Post# 686718 , Reply# 12   7/1/2013 at 19:42 (3,951 days old) by rp2813 (Sannazay)   |   | |
Mark, you probably remember the complaint Nate and I had with the steam cycles, that the steam process took so long that the supply of hot water to the machine for any remaining fills had cooled off. Mileage can vary on this issue based on the machine's distance from the water heater.
There is one area where these machines excel, and that is with drying. No other dishwasher I've ever used has come close out-drying the Thermador. Rarely was there any water in cup bottoms or other concave pieces on the top rack. A great system.
Sounds like your basement is well equipped for a dishwash-in . . . |
Post# 686723 , Reply# 13   7/1/2013 at 20:13 (3,951 days old) by william637 (Damp pants? Not a chance. )   |   | |
Over the past 15 months I have acquired about 23 dishwashers - some for parts, and others as part of a restoration project. My first goal on all of the restoration projects is just to get them functional (pump water without leaking). After this, I am going to through one by one and start cleaning up panels and trim (most all of pitting or rust somewhere on them).
I have built a rack in my basement that holds 8 dishwashers thus far. I have a hot water run to them, and plans to install a circulation pump that I can run when I want to use the dishwashers so the water stays hot in the loop. I haven't fully plumbed the drain - right now I just have a pipe that runs into a bucket, so I have to empty the bucket after every drain. Eventually, I will get the basement finished like I want it, but time and money are against me.., So, it is very much a work in progress, but if anyone is ever in NC, I welcome them to drop by. If I can get things cleaned up at least a little bit down there I may be planning on a dish-wash in next spring or summer. |
Post# 686725 , Reply# 14   7/1/2013 at 20:14 (3,951 days old) by william637 (Damp pants? Not a chance. )   |   | |
Post# 686730 , Reply# 15   7/1/2013 at 20:31 (3,951 days old) by rp2813 (Sannazay)   |   | |
