Thread Number: 47258
Kenmore portable washer leaking |
Post# 686532 , Reply# 1   6/30/2013 at 19:03 (3,952 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 686544 , Reply# 2   6/30/2013 at 20:23 (3,952 days old) by wringer (x)   |   | |
same model and it also sprung a leak. It had 12 service calls prior to this so junked it and bought a new GE portable pair and they far excel the Kenmore. |
Post# 686562 , Reply# 4   6/30/2013 at 21:54 (3,952 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 686602 , Reply# 5   7/1/2013 at 06:10 (3,952 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 686608 , Reply# 6   7/1/2013 at 06:41 (3,952 days old) by kenmore700bill (Lodi NJ)   |   | |
If it is not the seal, my money is on the rubber corrigated boot that runs from the tub to the pump. These tubs move freely and jump around in the spin cycle that wears them or splits the bood, I had similar issue drove me nuts until I took off the boot and saw the split once I took it off and stretched it out small crack on innser seam.. I replace 2 of them in the washers life...
Post# 686715 , Reply# 7   7/1/2013 at 18:47 (3,951 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 686791 , Reply# 9   7/2/2013 at 06:46 (3,951 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
From your further description it sounds like it is not quite a flood so it could be the main seal. Question how does the washer sound at full spin speed, if it roars like a fright train passing by it likely does have a bad main seal and bearings, in which case take any good parts you want off the machine on its way out to the recycler. |
