Thread Number: 47320
The 1970 avocado Kenmores have landed (in my basement)! |
Post# 687280   7/4/2013 at 13:52 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
My brother and I went to pick up the 1970 avocado Kenmore's this morning and they are safely in my basement! After a cursory inspection and photo shoot I can report the following:
1. The dryer appears to be in very good condition. Pictures and details to follow below. 2. The washer less so but nothing that restorative work cannot repair.
The dryer console: |
Post# 687281 , Reply# 1   7/4/2013 at 13:53 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687282 , Reply# 2   7/4/2013 at 13:53 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687283 , Reply# 3   7/4/2013 at 13:54 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687284 , Reply# 4   7/4/2013 at 13:55 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687285 , Reply# 5   7/4/2013 at 13:56 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687286 , Reply# 6   7/4/2013 at 13:57 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687287 , Reply# 7   7/4/2013 at 13:58 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687289 , Reply# 8   7/4/2013 at 14:02 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Console close-up: Note that the backlight is on whenever the machine is in a cycle, the neon indicator light comes on ONLY for the timer increments that begins a cycle with an Alphabet Letter. For example if you turn the timer to letter "B" the neon light comes on and stays on until the timer advances to the 8 minute mark of the Regular cycle. |
Post# 687290 , Reply# 9   7/4/2013 at 14:02 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687291 , Reply# 10   7/4/2013 at 14:11 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Other observations of the washer: The suds valve is toast. It is the older style aluminum body valve and one of the inlets has completely corroded off. For the time being I will plumb around that and make it a non-suds machine. The basket brake seems to be pretty much shot. I can spin the tub by hand easily and it takes about 15-20 seconds for the tub to stop spinning. The entire motor/drive assembly seems loud, especially when agitating. I'm not sure if this is a function of the fact that it's not balanced and level right now or if there are more serious issues.
I think this set is again one of those situations where the washer saw pretty normal use for many years and is tired. The dryer, however, probably saw less than half of the use since she most likely hung a lot of things out to dry.
My initial plan is to get the dryer vacuumed out, cosmetically spiffed up and put directly into use. I'm pretty stoked to have a WP gas dryer with TRUE soft heat and automatic dryness control to use. The 1967 Maytag HOH will have to languish in storage for a while.....
I will most likely play with the washer for a few weeks and then set it aside for moderate to major Belt-Drive Rebuild. God only knows what the spin tube, center post and center post bearings look like! |
Post# 687299 , Reply# 11   7/4/2013 at 15:27 (3,948 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The KM dryer is a much better dryer than the Maytag. You will enjoy its performance and capacity. What is the BTU rating; about 25,000? |
Post# 687305 , Reply# 12   7/4/2013 at 16:26 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Tom, 25,000 btu at full tilt. I will scan and post the electrical schematic here for those that want to try to figure out how this machine works it "Soft-Heat" magic.
I just finished cleaning it and hooked it up. It is SOOO quiet. It heats right now that's all I can say about it. Perhaps later this evening or in the morning I will dry in it for the first time!
While it is not the "Super Capacity" of the later Kenmore dryers, I bet it can handle a full 16-18 lb. load from my 1984 Whirlpool 7800! |
Post# 687306 , Reply# 13   7/4/2013 at 16:29 (3,948 days old) by jetaction (Minneapolis)   |   | |
Post# 687309 , Reply# 14   7/4/2013 at 16:38 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687310 , Reply# 15   7/4/2013 at 17:22 (3,948 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yay Mark, you will love this dryer, the Fabric Master automatic dry cycle works in a very unique way on this dryer. The pink and red wires you see on the left side of the gas valve connect to a micro-switch that closes and completes a circuit to the timer motor when the flame is modulated down to the minimum size. Normally this will not happen until almost all moisture is evaporated from the clothing load being dried. This is very similar to the dry control system used on 29" KM gas combos. In theory it should work very well, however KM only ever used this system on a few dryers as your Gas Dryer is one of the last to have this Great Modulating Gas Burner. |
Post# 687312 , Reply# 16   7/4/2013 at 17:32 (3,948 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Great set! Those consoles with their Octagon windows are cool as hell. And that 2nd rinse option too. Being WP/KM and abundant machines, you should be able to get the suds valve replaced, then you'll be the envy of the club. This post was last edited 07/04/2013 at 20:52 |
Post# 687323 , Reply# 18   7/4/2013 at 18:03 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687326 , Reply# 19   7/4/2013 at 18:05 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687327 , Reply# 20   7/4/2013 at 18:07 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687328 , Reply# 21   7/4/2013 at 18:10 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687330 , Reply# 22   7/4/2013 at 18:11 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687335 , Reply# 23   7/4/2013 at 18:30 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687347 , Reply# 24   7/4/2013 at 19:18 (3,948 days old) by Tomturbomatic (Beltsville, MD)   |   | |
I've picked up those suds valves at the parts place so they are or were available recently. I think they have plastic bodies now, but I didn't examine them that closely. Friends had those machines and those cast control panels are weighty. |
Post# 687352 , Reply# 25   7/4/2013 at 19:37 (3,948 days old) by appnut (TX)   |   | |
Aren't these the very same model machines that were used in Karen Fairgate's kitchen on the set of Knotts Landing?
OOB switch and buzzer working correctly? Uhh, did I spy sheets and towels in that load together? I learned with the 1964 Norge Dispensomat and the 1970 Kenmore 800 you don't mix items like that and not suffer an OOB in almost every spin. Sheets with sheets and towels and underwear together. I bet the Wrinkle Guard is the style which tumbles 10 or 15 seconds every 5 minutes. Now as to whether it does that for 45 minutes or 2.5 hours? I dont' think Sears "messed" with the Wrinkle Guard feature until the ubiquitous center dial Kenmores emerged with their black faced panel in the mid 1970s. Winkle Guard then became I with 30 minutes of continuous tumbling; II with the inetermittant tumbing on the timer dial for 45 minutes; and III was for the LK and still did the 2.5 hours maximum or until you opened the door. |
Post# 687361 , Reply# 26   7/4/2013 at 20:26 (3,948 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 687378 , Reply# 27   7/4/2013 at 21:48 (3,948 days old) by A440 ()   |   | |
Fantastic Find! |
Post# 687380 , Reply# 28   7/4/2013 at 21:59 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687382 , Reply# 29   7/4/2013 at 22:48 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
I never bothered to mention in THIS thread that these are my "dream" machines. This is THE washing machine that I grew up with until I was 12 years old, except that our machines was white. Our dryer was a 1967-ish Kenmore model 70. Here is a picture of those actual machines that I took using my Kodak Instamatic in the summer of 1980 when we were remodeling the basement and creating a new laundry room. Our machine was also a suds-saver. |
Post# 687383 , Reply# 30   7/4/2013 at 23:07 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687384 , Reply# 31   7/4/2013 at 23:08 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687385 , Reply# 32   7/4/2013 at 23:09 (3,948 days old) by PhilR (Quebec Canada)   |   | |
Post# 687386 , Reply# 33   7/4/2013 at 23:10 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687395 , Reply# 35   7/5/2013 at 01:33 (3,948 days old) by A440 ()   |   | |
What great prices! |
Post# 687396 , Reply# 36   7/5/2013 at 01:35 (3,948 days old) by appnut (TX)   |   | |
Mark, that model was the one I wanted when it came time to replace the dead 1964 Norge Dispensomat with the 8 programmed cycle buttons I didn't agree with--after all, I'd learned to do laundry the Lady Kenmore way and those 8 Norge cycles didn't match. After all, this machine had everything I thought was basic necessity--could chose all your own options and had all the requir3ed basic cycles. Thankfully the mom wanted something with a bit more dazzle and lighted console to it, the infamous Kenmore 800 and that is what we ended up with. We paid like $249 for the Kenmore 800. What was the price for that one that was Pedestrian Mark?
Post# 687406 , Reply# 37   7/5/2013 at 06:40 (3,948 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 687433 , Reply# 38   7/5/2013 at 09:27 (3,948 days old) by Tomturbomatic (Beltsville, MD)   |   | |
and a three position water level control instead of an infinitely variable control. |
Post# 687435 , Reply# 39   7/5/2013 at 09:53 (3,948 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Here's the full scan of the 60 model from 1970 Spring/Summer catalog as requested.
It is curious how similar these machines really are from a cycle standpoint. I suspect that they use the same timer and both have the self-cleaning lint filter.
The only differences I can see in features are: 1. The lack of timed bleach & fabric softener dispensers, the 60 having the agitator-mounted dispenser. 2. The manual water temp control which would like preclude the use of a cold rinse on the hot and warm settings unless you changed the dial after the wash filled. 3. The 3-position water level switch instead of the infinite. |
Post# 687442 , Reply# 40   7/5/2013 at 11:09 (3,947 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Mark -
Let me guess, your washer's model number is 110.7005700 or something nearby up to 110.7005704. If it was 110.7004700 (non-suds) the first few revisions use timer 362357, while the later versions use timer 363089. They both sub to 373844 as the last available WP/FSP timer. The "pedestrian" 60 series non-suds machine is model 110.7004610. These went all the way up to 110.7004619 in revisions except for some reason they skipped 612 and 614. Early versions use timer 363385 which subs over to 379372, which was a very common timer and is still typically widely available on ebay. This timer was used in several other mid-line machines from 1970 that I have or had. Thus the 60 and the 70 didn't use the same timer. That is not unusual, as Sears usually spec'd a different timer for machines without solenoid controlled dispensers. The 70-series' timer may have been useable in models with water flushed detergent dispensers as well. Some of the engineer's rationale often doesn't seem to make sense as to why they used what, but it clearly made sense to them at the time. Sometimes the only difference in a timer is the presence of a dry agitate in the normal cycle or not, whether or not the timer can be used as-is in suds models, whether is has fast or slow agitation in Pre-Wash, etc. The difference may also rest in how the knobs attach as well (some had timer hubs and others screwed directly on). I think the 60-series model from your catalog shot was pretty long-lived. It was even re-invented in 1972 with a bronze color inset on the left console instead of charcoal. Gordon |
Post# 687443 , Reply# 41   7/5/2013 at 11:20 (3,947 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
By the way Mark,
FANTASTIC save on the pair, the dryer looks mint just as you said. The washer looks great too. Oddly, the first time I ever saw one of these machines was an Avocado model just like yours in the repair shop at the Sears parts depot near downtown Denver in early 1981. I really studied the panel as it reminded me of a radio as others have said here. This was when I talked my Dad into helping me repair our 1974 Kenmore which had a premature basket-drive failure --- we were getting a tutorial from a nice service guy who basically told us how to do everything. Fixing that machine led us to cancel the 1980-model Kenmore 70 that my Mom had bought a day or two before --- the same model that you had I believe. This was also the weekend adventure that led me to develop my washer rebuilding hobby that I've so enjoyed for many years since. Gordon |
Post# 687445 , Reply# 42   7/5/2013 at 11:38 (3,947 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Gordon, the parts lists that came with the machine lists it as 700(4/5)701. The timer in that book is listed as #363089 and makes no distinction between suds and non-suds. Good to know what that timer subbed to in later years. I'll be doing periodic searches to find a replacement timer to have "on hand" so that this machine doesn't suffer the same fate as my 1967 800. I'm guessing that this timer MAY be a bit more common than that one! |
Post# 687470 , Reply# 43   7/5/2013 at 14:13 (3,947 days old) by bajaespuma (Connecticut)   |   | |
Those are freakin' gorgeous! I love that control panel design even though I prefer the ones with lots of buttons, bells and whistles. Elegant and classic lines. I guess the pink in this illustration is not accurate if, indeed, these models were only a 1970 offering. Just gotta love those Lucite backlit control dials:
Post# 687531 , Reply# 46   7/5/2013 at 21:39 (3,947 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687532 , Reply# 47   7/5/2013 at 21:40 (3,947 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687533 , Reply# 48   7/5/2013 at 21:43 (3,947 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 687560 , Reply# 49   7/6/2013 at 00:02 (3,947 days old) by A440 ()   |   | |
So... What did you think about the dryer? Did you dry the full load from the washer? Did you watch the burner modulate while it was in operation? I bet it is a fun dryer! It is in such great shape! You lucky guy! |
Post# 687577 , Reply# 50   7/6/2013 at 08:03 (3,947 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Everything about the dryer seems to be good. It does seem to have a slight intermittent squeak in the tumbling. I suspect that cleaning and oiling the rollers and replacing the belt will likely do the trick. After 43 years it's likely time!
I did dry several loads in it. I didn't time the drying but it certainly seems to be fast. I haven't actually laid on the floor to watch the burner modulate, but I do have a thermometer in the exhaust duct and I did notice that when the exhaust temp reaches about 150 that the flame is at less than half and that the temp stayed at pretty much exactly 150 until the burner shut off. |
Post# 688818 , Reply# 51   7/11/2013 at 20:01 (3,941 days old) by electronicontrl (Grand Rapids, MI)   |   | |
I have my coppertone duo in my basement now for 15 months and I have not connected the dryer up yet. That soon will change as this thread has got me excited. I bought this Kenmore 800 washer w/ Suds and 900 dryer from Captain Moody. The dryer appears to have been seldom used. I'll look for that capillary tube........
Post# 979989 , Reply# 52   1/26/2018 at 10:48 (2,281 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Well, here is a sort of a rough draft that I made, of mine, doing a (rather, very) pale imitation:
-- Dave
