Thread Number: 47701
Motor control Boards |
Post# 694201 , Reply# 1   8/4/2013 at 13:18 (3,918 days old) by DaveTranter (Central England)   |   | |
Finally had time to dig one out.... Does anyone have any knowledge of the connections and/or inner workings of the Elmarc EM13 SP controller?? There will be others as and when I can get to them... Thanks in advance Dave T |
Post# 694352 , Reply# 2   8/5/2013 at 03:42 (3,917 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 694354 , Reply# 3   8/5/2013 at 04:15 (3,917 days old) by electron1100 (England)   |   | |
Post# 694355 , Reply# 4   8/5/2013 at 04:15 (3,917 days old) by electron1100 (England)   |   | |
Post# 694356 , Reply# 5   8/5/2013 at 04:15 (3,917 days old) by electron1100 (England)   |   | |
Post# 694437 , Reply# 6   8/5/2013 at 16:14 (3,916 days old) by DaveTranter (Central England)   |   | |
I'll try to get one or two done... I'll try to dig out a few more controllers and motors, too... Thanks for your interest Dave T P.S. I heard you the first time, Electron1100.... ;-) |
Post# 696590 , Reply# 9   8/15/2013 at 01:58 (3,907 days old) by crouzet951 ()   |   | |
This is the module in situ. Looking at the back of the machine, it is in the lower left side. There are four terminals on top (two are common), and a multi-connector on the bottom. |
Post# 696591 , Reply# 10   8/15/2013 at 02:00 (3,907 days old) by crouzet951 ()   |   | |
This is what the motor looks like, though usually not as rusty as this one. Drive is poly-v belt. |
Post# 696592 , Reply# 11   8/15/2013 at 02:01 (3,907 days old) by crouzet951 ()   |   | |
Rear of the motor. |
Post# 696597 , Reply# 14   8/15/2013 at 02:40 (3,907 days old) by crouzet951 ()   |   | |
The motor speed at distribute can be adjusted slightly, using a trim pot on the module, and a small screwdriver. It's described in paragraphs 16 and 17 of the attached. |
Post# 697523 , Reply# 16   8/19/2013 at 14:18 (3,902 days old) by DaveTranter (Central England)   |   | |
Hope this helps with identification...... |
Post# 697681 , Reply# 18   8/20/2013 at 08:17 (3,902 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 697823 , Reply# 20   8/21/2013 at 01:48 (3,901 days old) by tolivac (greenville nc)   |   | |
Not only fans and motors-but I have seen that same circuit used in incandescent light dimmers.It could be used for flourescents-but the lamp has to have a dimming ballast to work. |
Post# 700353 , Reply# 23   9/1/2013 at 05:39 (3,890 days old) by DaveTranter (Central England)   |   | |
Surely SOMEONE has had a 'play' with motors and controllers before!!! I have thought of several more potential 'projects', including a motor-generator set, for which close speed regulation will be a 'must'.... Can anyone help??? All best Dave T |
