Thread Number: 48338
kds 18 poor cleaning |
Post# 700575 , Reply# 1   9/2/2013 at 06:11 (3,889 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 700609 , Reply# 3   9/2/2013 at 11:35 (3,889 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Actually this is THE MOST COMMON service complaint from customers on about any KA DW from the 15s-the 22 series.
KA DWs while very good machines overall were a little bit overly complicated and were much more often plagued by things going wrong that impacted their ability to clean well.
Most Common Problems, 1 clogged wash filter, 2 detergent dispensers that do not open [ often because of clogged wash filter or bad inlet valve, bad wash arm support or item stuck in drain valve ] 3 Bad inlet valve which allows insufficient water flow [ almost NEVER a clogged inlet screen ] 4 broken wash arm support and worn lower wash arm. 5 Item caught in drain valve holding it open or blocking a full drain, on 15-20 models 6 Bad Drain check valve on 21 and 22 models [ CV does not seal any longer which allows pump to pull air back into DW when washing and rinsing which greatly reduces water pressure especially in top rack ] 7 Bad-broken drain impeller in 15-20 machines that causes poor drain. 8 Hole in rubber tube going to top wash arm in 18-22 models, and feed spout for upper wash arm feed out of place or missing altogether.
There are also a large host of problems related to detergent usage and water temperature and condition that will affect ANY DW ability to do a decent cleaning job. |
Post# 700634 , Reply# 4   9/2/2013 at 13:31 (3,889 days old) by rp2813 (Sannazay)   |   | |
Water temperature is the first thing I'd check. It should be at 120 degrees or higher, and you should run the tap to get it up to that temperature before starting the dishwasher.
My sister got rid of a perfectly good KDS-18 because she said it didn't get anything clean and even spewed black particles onto the contents. It was simply a case of her not using the machine enough (like almost never -- she's single) and that it needed a good cleaning and de-crusting from sitting unused so much of the time. With her being 350 miles away, I wasn't able to do the work for her myself and save her the expense of a new dishwasher. |
Post# 700641 , Reply# 5   9/2/2013 at 14:33 (3,889 days old) by epixstar128 (toledo)   |   | |
The top arm looks like it never moves. The brass ring in the support arm came out. I cleaned the inlet filter and the detergent cups open when they need too. |
Post# 700649 , Reply# 6   9/2/2013 at 15:16 (3,889 days old) by epixstar128 (toledo)   |   | |
Pic of the support arm pin |
Post# 700710 , Reply# 11   9/2/2013 at 20:10 (3,888 days old) by epixstar128 (toledo)   |   | |
Hope its the right part spent 50 bucks on it |
Post# 700936 , Reply# 13   9/3/2013 at 18:30 (3,887 days old) by epixstar128 (toledo)   |   | |
Cool thanks get me the info i will prob do that. I work on hvacr for a living gets old working on your stuff when you get home |
Post# 700942 , Reply# 14   9/3/2013 at 19:22 (3,887 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 700943 , Reply# 15   9/3/2013 at 19:24 (3,887 days old) by epixstar128 (toledo)   |   | |
Impeller looks good will wash out the arms |
Post# 700959 , Reply# 18   9/3/2013 at 20:34 (3,887 days old) by epixstar128 (toledo)   |   | |
Looks great do you have any of the pn by chance to do this conversion |
Post# 701035 , Reply# 19   9/4/2013 at 05:42 (3,887 days old) by stevet (West Melbourne, FL)   |   | |
but will post them later today. |
Post# 701053 , Reply# 20   9/4/2013 at 07:13 (3,887 days old) by barcoboy (Canada)   |   | |
I don't know if I could modify my KDS-58 this way. I know it is Hobart parts out, Hobart parts in, but to me, what is the first thing that I see when I look in my tank that screams Hobart? 4 way Hydrosweep. I mean, how many years did they use a 4 way wash arm?
Of course, if it meant bringing my 58 back to usuable condition, I wouldn't hesitate to do it. But to modify a good working unit... I don't know... it seems kind of sacrilegious! Maybe it's just me. |
Post# 701169 , Reply# 21   9/4/2013 at 14:51 (3,887 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 701393 , Reply# 22   9/5/2013 at 15:24 (3,886 days old) by jkbff (Happy Rock, ND)   |   | |
