Thread Number: 48511
Kenmore Agitator Removal |
Post# 702842 , Reply# 1   9/12/2013 at 10:41 (3,879 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Tom -
You can put a lot of force on the agitator in your efforts, in fact I have briefly picked-up machines off their feet trying to get the agitator out. If it turns out "stucker-than-stuck" you can use an agitatmer, which employs an empty bladder like a hot water bottle, which you seat under the agitator. Once tucked under, you fill that agitamer with water from a hose, and the expansion of the bladder pushes the agitator up --- sometimes gradually, other times all of a sudden. I'd say feel free to put some pressure on the situation, it won't hurt the machine. Just pull straight up. Gordon |
Post# 702843 , Reply# 2   9/12/2013 at 10:43 (3,879 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 702844 , Reply# 3   9/12/2013 at 10:49 (3,879 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 702847 , Reply# 4   9/12/2013 at 11:04 (3,879 days old) by kenmore70 (New York)   |   | |
Thanks all for your assistance. Maybe I'll host an agitator removal party and have a few of my friends try to help me lift it out. Of course I won't tell them this until they get here, they may not show up!!!!!!! |
Post# 702871 , Reply# 5   9/12/2013 at 13:09 (3,879 days old) by Yogitunes (New Jersey)   |   | |
with the top in place, lid open.....lay down a few towels across the machine edges, on top of them lay down a 2x4 across the machine centered over the agitator, and with 2 racheting ties down, criss-crossed under the agitator and up around the 2x4.....and start to rachet both at the same time....this should pull the agitator off the machine.....
simplest method I have used so far......adding some penetrating oil down the center doesn't hurt either... |
Post# 702936 , Reply# 6   9/12/2013 at 16:49 (3,879 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 702939 , Reply# 7   9/12/2013 at 16:57 (3,879 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
Is there a bolt or nut in that hole on the top of the agitator? That could keep it on the machine. |
