Thread Number: 48615
Kitchen Aid washer stops during cycle ..and oil leak! |
Post# 704409   9/21/2013 at 10:49 (3,870 days old) by moparwash (Pittsburgh,PA )   |   | |
..and sometimes after it fills, it will agitate once and stops. If I reset the timer to another part of a cycle that has agitation, nothing happens, but if I put in drain or spin, it does drain or spin. I replaced the timer and that solved that problem for a few weeks and now thinking its the lid switch, though when it spins and I open the lid and it stops spinning, so the switch works at least to stop the spin...any ideas before I throw more money at this thing?...(this was supposed to replace the Neptune I couldn't get to spin, so I am having the best luck!)...and found some oil on the floor This post was last edited 09/21/2013 at 15:04 |
Post# 704412 , Reply# 1   9/21/2013 at 11:10 (3,870 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 705190 , Reply# 2   9/24/2013 at 21:28 (3,866 days old) by kenmorewasher10 ()   |   | |
would you mind taking a picture of the inside and make a video of what you say it's doing |
Post# 705248 , Reply# 3   9/25/2013 at 07:36 (3,866 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yes I would inspect the power connections at the motor and look for any signs of overheating, also look at the wires on the motors overload protector [ located just above the motor centrifugal switch ] for burned wires. You could also bypass the lid SW to be sure that something unusual is not happening there. A small oil leak on these washers is not a good thing in the long run but usually does not keep them from going for a while longer.
Jerry you are just going to have to start buying your vintage at a different place, I am still on the lookout for a good Neptune FL stack washer, John. |
Post# 705890 , Reply# 4   9/28/2013 at 09:14 (3,863 days old) by moparwash (Pittsburgh,PA )   |   | |
