Thread Number: 48767
replaced dead ka washer with kenmore 90 series
Post# 706323   9/30/2013 at 10:58 (3,861 days old) by moparwash (Pittsburgh,PA )
moparwash's profile picture
So far so good...needs agitator dogs...can the max water level be increased on this?..any user opinions on this model.?
Post# 706324 , Reply# 1   9/30/2013 at 11:07 (3,861 days old) by henene4 (Heidenheim a.d. Brenz (Germany))
Don't get the dial set up. Why is there only UltraClean and PermPress 2?
Post# 706326 , Reply# 2   9/30/2013 at 11:19 (3,861 days old) by moparwash (Pittsburgh,PA )
The speed selector knob lets you choose the agitate and spin speeds so you can create heavy ..regular...delicate and hand wash cycles
Post# 706327 , Reply# 3   9/30/2013 at 11:22 (3,861 days old) by mtn1584 (USA)
Sears Best!!!!
In 1999 / 2000 this washer was Consumer Reports # 1 tested washer, as well as Sears Best top loader at the time. This is one of the few KENMORE MODELS in recent years that had a Speed Switch!!! My favorite....this is why you only have Ultra Wash and PP cycles, because with the speed switch you can create any number of customized wash and spin speed cycles. This is my favorite Kenmore console of all time. A very good washing machine,,,,dogs are a cheap fix.
Mike
Post# 706358 , Reply# 4   9/30/2013 at 14:08 (3,861 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)
foraloysius's profile picture
There was a previous model that was almost similar but also had a hot-warm temperature selection. Very flexible machine!
Post# 706419 , Reply# 5   9/30/2013 at 18:26 (3,860 days old) by Yogitunes (New Jersey)
yogitunes's profile picture
you should be able to open the control panel and turn the set screw clockwise to increase the water level higher...just do it in small increments, and check the level after turning it to RESET....
very nice machine......the variations of cycles and speeds are endless......one of the better models to choose for user flexability......
you can find those 'dogs' on ebay for cheap.....and easy to install....
CLICK HERE TO GO TO Yogitunes's LINK on eBay
Post# 706442 , Reply# 6   9/30/2013 at 20:28 (3,860 days old) by moparwash (Pittsburgh,PA )
Dogs ordered...should be all ready for the 2014 wash in!
Post# 706449 , Reply# 7   9/30/2013 at 21:06 (3,860 days old) by Mich (Hells Kitchen - New York)
HOLY CRAP..
mich's profile picture
Does it have a water heater? I see the words, auto temp control ;)
Post# 706452 , Reply# 8   9/30/2013 at 21:12 (3,860 days old) by moparwash (Pittsburgh,PA )
It supposed to mix the water to the selected temperature
Post# 706458 , Reply# 9   9/30/2013 at 21:42 (3,860 days old) by DirectDriveDave ()
Technically, if you ever wanted to, you can still get a Hot/Warm. Simply move the dial to the warm rinse after the wash finishes filling, another awesome part of the mechanical control.
Post# 706488 , Reply# 10   9/30/2013 at 23:50 (3,860 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))
Excellent Washer!
You've latched on to one of the BEST TL, AW's ever.  The reliability, thorough cleaning, and cycle flexibility are outstanding.  Also being a WP built DD machine it is easy to service and parts are plentiful.  That is on the few occasions it needs it.   I can think of very few Tl washers vintage or modern that could match or beat it.
WK78
Post# 706570 , Reply# 11   10/1/2013 at 12:30 (3,860 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)
Found a close up picture of the temp control.
Post# 706580 , Reply# 12   10/1/2013 at 13:11 (3,860 days old) by DirectDriveDave ()
Look at all those options it used to give back then, so wonderful.....
Post# 706593 , Reply# 13   10/1/2013 at 14:14 (3,860 days old) by kenmore700bill (Lodi NJ)
kenmore700bill's profile picture
Jerry,
This is not like the old screw that is visible it is a round white sealed unit. I have the same washer, in order for me to raise the water level I had to flip the console up, take off the control knob for the water level switch, dismount the switch from the console. To do this you have a plastic tab that you must push down to release the switch from the mounting bracked and the switch will fall in your hands,(you need to be careful if you break that plastic tab you are done there are no mounting screws on this water level switch) once you look at the front of the switch it will be a tiny silver screw you need to turn I mean tiny I used a needle nose piers to get to it. I turned it a half turn and brought me right above the top row of lines in the tub. ( i did fill with water while i had the switch dismounted in case I had to re-adjust.)
Thanks
Bill
Post# 706621 , Reply# 14   10/1/2013 at 16:27 (3,859 days old) by lakewebsterkid (Dayton, Ohio)
Catalyst Option?
Did these machines come with the catalyst option as a feature in even higher models? I believe I had one when I was younger but I'm unsure. If they did, that would be a nice find!
Post# 706664 , Reply# 15   10/1/2013 at 20:48 (3,859 days old) by Mich (Hells Kitchen - New York)
I love...
All of the Water Temp Options.. especially the automatic controls. Makes sure the Cold in the line gets flushed with the right amount of hot to get to the right temperature..
Such a useful feature :)
