Thread Number: 49322
Whirlpool imperial mark XII washers |
Post# 713611   11/6/2013 at 22:08 (3,823 days old) by arris (Rochester New York)   |   | |
Post# 713651 , Reply# 1   11/7/2013 at 07:59 (3,822 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 713654 , Reply# 2   11/7/2013 at 09:07 (3,822 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 713673 , Reply# 3   11/7/2013 at 10:53 (3,822 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 713674 , Reply# 4   11/7/2013 at 11:00 (3,822 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 713700 , Reply# 5   11/7/2013 at 14:05 (3,822 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 713701 , Reply# 6   11/7/2013 at 14:06 (3,822 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 713706 , Reply# 7   11/7/2013 at 14:41 (3,822 days old) by AtomicT (Middletown, NY)   |   | |
Post# 713707 , Reply# 8   11/7/2013 at 14:48 (3,822 days old) by lakewebsterkid (Dayton, Ohio)   |   | |
Is that what I am reading on the dryer in the last post? If so, that is awesome! Never have I seen that before! Please show a demonstration!! |
Post# 713731 , Reply# 9   11/7/2013 at 15:54 (3,822 days old) by DADoES (TX, U.S. of A.)   |   | |
Yes, Whirlpool offered multiple tumble speeds on top-of-the-line and near-top-of-the-line models for a few years. The motor had a cone-shaped pulley and a wide idler pulley. The mechanical shift mechanism positioned the belt to different diameter areas of the pulley for the available speeds. Instructions advised not to change the speed unless the dryer was running -- press Start first to get it going, then set the speed. Three speeds were available: - Fastest speed for large or bulky items such as sheets and blankets - Medium speed for "normal" items - Low speed for light-weight delicates It was reduced to two speeds for the last year the feature was offered (the LDA-9800 series which is the gold pair in Reply #3). The avocado dryer in Reply #6 is a 1974 LAE-8800, one step below top-of-line, still had 3 speeds. LAE-9800 would been the top-of-line for 1974, also had 3 speeds. Note that the tumble speed selector is a different thing from earlier dryers that offered two drying speeds via a rotary control, usually labeled Super & Gentle. The drying speed control did not affect tumble speed, it changed the airflow rate via either shifting the blower belt on a dual pulley or a damper door in the exhaust (when the design was changed to a direct-drive blower). |
Post# 713734 , Reply# 10   11/7/2013 at 16:11 (3,822 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 713736 , Reply# 11   11/7/2013 at 16:12 (3,822 days old) by akronman (Akron/Cleveland Ohio)   |   | |
10 cycles plus a pre-wash or extra rinse. The final button above the dial, unlabeled, would be for the suds models. That piece of tape #2 is for cycle 2, my favorite, because the button for it is slightly stuck, and I do NOT want to get into the pushbutton assembly. All the other buttons work perfectly, just #2 kind of slips past its stop, so knowing where to find it makes for a perfect cycle. |
Post# 713737 , Reply# 12   11/7/2013 at 16:17 (3,822 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 713779 , Reply# 13   11/7/2013 at 20:32 (3,822 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 713790 , Reply# 14   11/7/2013 at 22:01 (3,822 days old) by mickeyd (Hamburg NY)   |   | |
Post# 713792 , Reply# 15   11/7/2013 at 22:06 (3,822 days old) by mickeyd (Hamburg NY)   |   | |
Post# 713797 , Reply# 16   11/7/2013 at 22:22 (3,822 days old) by norgeway (mocksville n c )   |   | |
The pushbuttons! |
Post# 713869 , Reply# 17   11/8/2013 at 08:36 (3,821 days old) by polkanut (Wausau, WI )   |   | |
Post# 713899 , Reply# 18   11/8/2013 at 11:25 (3,821 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
