Thread Number: 49337
Kenmore Waher Agitator Replacment |
Post# 713775 , Reply# 1   11/7/2013 at 20:15 (3,827 days old) by Yogitunes (New Jersey)   |   | |
first of all is this the large base agitator from the KA?....
for whats its worth, that agitator will work no matter what...for the most part, KA used medium/slow agitation with that larger base unit....I put these in 2 speed machines, with great rollover results....some claim transmission premature wear, but never had an issue..... if anything, use this larger base with low or medium agitation and and spin speed, although I always preferred high speed for both.... I match mine with a white spiral, I just don't like the blue..... |
Post# 713916 , Reply# 2   11/8/2013 at 12:39 (3,827 days old) by speed_queen75 ()   |   | |
Yes it is the large base agitator for the KA, my kenmore has a 3 speed motor with 5 different spin wash combinations. |
Post# 713990 , Reply# 3   11/8/2013 at 19:27 (3,826 days old) by speed_queen75 ()   |   | |
The triple action agitator of the kenmore? |
Post# 714018 , Reply# 4   11/8/2013 at 20:45 (3,826 days old) by Yogitunes (New Jersey)   |   | |
triple action...that has a unique way to dismantle it and get it out....
this video will give you an idea of how to get the spiral and dogs out.....one more bolt on top of the base needs removed, and it should all lift out... its easier to explain thru this video that trying to tell you.....he's using needlenose pliers to remove that plastic bolt, I use a large drive extension on a ratchet.....a very wide blade screwdrivers works too....what is ever easier for you.... not many removal videos for this type of dual action....but you should get the general idea... CLICK HERE TO GO TO Yogitunes's LINK |
