Thread Number: 49411
agitator operation |
Post# 714650 , Reply# 1   11/11/2013 at 17:02 (3,819 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 714727 , Reply# 2   11/11/2013 at 22:07 (3,818 days old) by washdaddy (Baltimore)   |   | |
Be patient...someone here will see the problem that you've posted and offer some assistance soon enough. Hopefully for your sake it will be something minor that you'll be able to take care of yourself. |
Post# 715111 , Reply# 3   11/13/2013 at 15:11 (3,817 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 715665 , Reply# 4   11/16/2013 at 08:13 (3,814 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 715724 , Reply# 6   11/16/2013 at 15:58 (3,814 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 716048 , Reply# 8   11/18/2013 at 11:19 (3,812 days old) by apostoln ()   |   | |
yes it is an A212 and it is a direct drive |
Post# 716052 , Reply# 9   11/18/2013 at 12:04 (3,812 days old) by DADoES (TX, U.S. of A.)   |   | |
It's not direct drive. Two belts are under the machine base. One runs from the motor to the pump at the right front corner. The other runs from the motor to the main drive pulley at the center. Perhaps I misunderstood the question via my initial response. The motor does run one direction for agitation, reverses to the other direction for drain & spin. If the machine drains & spins, and the motor doesn't run at all for agitation, then as others have said above the problem is possibly a bad timer or bad motor. |
Post# 716123 , Reply# 10   11/18/2013 at 19:36 (3,812 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 716124 , Reply# 11   11/18/2013 at 19:36 (3,812 days old) by maytaga806 (Howell, Michigan)   |   | |
