Thread Number: 49970
model i.d. |
Post# 721626   12/17/2013 at 13:27 (3,782 days old) by automech01 ()   |   | |
just bought a maytag washer & gas dryer wanted to know if anyone could help i.d. it heres the model # LAT8650BAW |
Post# 721641 , Reply# 1   12/17/2013 at 14:45 (3,782 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 721642 , Reply# 2   12/17/2013 at 14:57 (3,782 days old) by automech01 ()   |   | |
just wanted to know what they called them like A806 etc, wanted to know all i could about it like year made and dependability thanks for helping |
Post# 721658 , Reply# 3   12/17/2013 at 16:23 (3,782 days old) by Kenmore71 (Minneapolis, MN)   |   | |
That would be an LAT8650BAW. The 10 character model numbers on Maytags came into use in about 1991. This system replaced the older A806 or A712 type of model number.
Here's the decode: L=Domestic Laundry A=Automatic Washer T=Top loading, non-suds saver 8650=actual model number B=B series A=120 volts, 60 cycles, US electric code compliant B=Black Control Panel
That particular machine came from what was often referred to as the "1990" series because it was introduced in 1990. It replaced the "12" series machines. The "1990" series machine were made from 1990-1993. The series that followed was made from 1994-1996 and is often referred to as the "square panel Dependable Care". |
Post# 721707 , Reply# 4   12/17/2013 at 21:23 (3,782 days old) by automech01 ()   |   | |
thanks you guys are awesome |
Post# 721716 , Reply# 5   12/17/2013 at 21:59 (3,782 days old) by automech01 ()   |   | |
here are some more pics |
Post# 721717 , Reply# 6   12/17/2013 at 22:00 (3,782 days old) by automech01 ()   |   | |
another one |
Post# 721718 , Reply# 7   12/17/2013 at 22:04 (3,782 days old) by automech01 ()   |   | |
looks like it was leaking from around bleach line any ideas on how to repair it has a oval port doesn't look like a clamp would seal all the way round |
Post# 721719 , Reply# 8   12/17/2013 at 22:04 (3,782 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 721721 , Reply# 9   12/17/2013 at 22:05 (3,782 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 721726 , Reply# 10   12/17/2013 at 22:57 (3,782 days old) by automech01 ()   |   | |
thanks picked them up for 125.00 what can you tell me about longevity and or pros and cons of these units |
Post# 721728 , Reply# 11   12/17/2013 at 23:03 (3,782 days old) by automech01 ()   |   | |
dryer is a LDG8420AAW A3331263HD washer is a A5108026HF LAT8650BAW |
Post# 721917 , Reply# 12   12/18/2013 at 21:59 (3,781 days old) by automech01 ()   |   | |
what type of soap should i use and where does it go. |
