Thread Number: 50145
Need help with DE50 |
Post# 723716 , Reply# 1   12/29/2013 at 17:40 (3,770 days old) by kitty ()   |   | |
I saw a belt for the fan on Repair Clinic and it would be about $40. I really don't want to pay $40 for a little belt. If you could find one somewhere else, that would be GREAT. |
Post# 725490 , Reply# 3   1/6/2014 at 09:57 (3,762 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 725500 , Reply# 4   1/6/2014 at 10:25 (3,762 days old) by kb0nes (Burnsville, MN)   |   | |
I can't be entirely sure from the blurry photo but is it a round urethane belt?
If so McMaster Carr likely has what you need. www.mcmaster.com/#urethane-round-... I think they have a vendor custom weld the loops if you order an O-Ring continuous belt. They also have a hollow belting that you can use with a coupler to make a loop. |
Post# 725648 , Reply# 5   1/6/2014 at 20:04 (3,762 days old) by TwinTubber (Toronto)   |   | |
I need the exact same belt. All other belts in the unit are made of rubber. But the exhaust fan made of silicone that gets brittle and cracks. |
Post# 726904 , Reply# 7   1/11/2014 at 09:50 (3,757 days old) by dnastrau (Lords Valley, PA)   |   | |
I think Twintubber was saying that the fan belt was silicone, not the fan. |
Post# 727869 , Reply# 8   1/15/2014 at 15:15 (3,753 days old) by kitty ()   |   | |
On mine, I have used two big o-rings for the fan belt and it works PREFECTLY. No problamos, so far. Anyway, thank you. |
Post# 729319 , Reply# 9   1/21/2014 at 09:14 (3,747 days old) by macboy91si (Frankfort, KY)   |   | |
Thanks for the link to the vendor. It seems to be the achilles heal of both the DE50 and A50. I purchased a new belt for the A50 a while back, and the weld broke (OEM Maytag belt) and the urethane belt on the dryer now slaps the shroud all the time which is what it did before it broke as well.
John, where did Jeff get his urethane belts made, I remember talking to him about it the last time I was there but I can't remember where he said. Thanks Tim |
Post# 770912 , Reply# 10   7/14/2014 at 18:58 (3,573 days old) by kitty ()   |   | |
I was doing a load and set it for about 45 minutes. Came back about 30 minutes later and timer hasn't moved. Anyone know where I can get a new one? |
Post# 771006 , Reply# 11   7/15/2014 at 07:17 (3,573 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 771012 , Reply# 12   7/15/2014 at 07:52 (3,573 days old) by kitty ()   |   | |
THX!!!!!!!!!!!! Hope they have one that will fit. THX again! |
Post# 771051 , Reply# 13   7/15/2014 at 12:45 (3,572 days old) by hippiedoll ( arizona )   |   | |
Post# 827740 , Reply# 15   6/12/2015 at 17:52 (3,240 days old) by Kitty ()   |   | |
Post# 827741 , Reply# 16   6/12/2015 at 17:54 (3,240 days old) by Kitty ()   |   | |
Post# 827742 , Reply# 17   6/12/2015 at 17:58 (3,240 days old) by Kitty ()   |   | |
Post# 827743 , Reply# 18   6/12/2015 at 18:04 (3,240 days old) by Kitty ()   |   | |
Post# 827744 , Reply# 19   6/12/2015 at 18:07 (3,240 days old) by Kitty ()   |   | |
Post# 827750 , Reply# 20   6/12/2015 at 18:46 (3,240 days old) by Kitty ()   |   | |
Post# 827751 , Reply# 21   6/12/2015 at 18:47 (3,240 days old) by Kitty ()   |   | |
Post# 827754 , Reply# 22   6/12/2015 at 18:49 (3,240 days old) by Kitty ()   |   | |
Post# 827755 , Reply# 23   6/12/2015 at 18:50 (3,240 days old) by Kitty ()   |   | |
Post# 829004 , Reply# 25   6/22/2015 at 10:37 (3,230 days old) by Kitty ()   |   | |
Thank you very much, and the washer is also holding up very well, fortunately. |
Post# 829006 , Reply# 26   6/22/2015 at 10:53 (3,230 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Did MT make a "halo of heat" gas dryer? I understand the design of the elc, but how did (if any) gas units "halo their heat"? |
Post# 829241 , Reply# 27   6/23/2015 at 17:00 (3,229 days old) by TwinTubber (Toronto)   |   | |
And good luck with everything. |
Post# 829251 , Reply# 28   6/23/2015 at 18:45 (3,229 days old) by hippiedoll ( arizona )   |   | |
Post# 829740 , Reply# 31   6/26/2015 at 18:16 (3,226 days old) by hippiedoll ( arizona )   |   | |
Post# 829742 , Reply# 32   6/26/2015 at 18:21 (3,226 days old) by Kitty ()   |   | |
Thank you, and I should have it running by Tuesday (I think) |
Post# 829775 , Reply# 33   6/26/2015 at 22:56 (3,226 days old) by hippiedoll ( arizona )   |   | |
Post# 830340 , Reply# 35   7/1/2015 at 16:25 (3,221 days old) by hippiedoll ( arizona )   |   | |
Post# 833298 , Reply# 36   7/22/2015 at 15:40 (3,200 days old) by macboy91si (Frankfort, KY)   |   | |
So did you source another belt for the blower? Just curious, glad you got that timer going. Such neat little dryers and they dry very well.
Tim This post was last edited 07/22/2015 at 16:03 |
Post# 834660 , Reply# 38   7/31/2015 at 15:26 (3,191 days old) by hippiedoll ( arizona )   |   | |
The screw-type thing works just as good (I think? ) because that's the kind that is on my maytag DE808 dryer and my dad's DE308 too! So if they're good enough for the full-size dryers, I'm pretty sure it'll be good enough for your DE50 portable/compact dryer too.
Glad you got it up & tumbling now... :o) |
