Thread Number: 5016
1958 Easy 'Regent' with Underlid Filter |
Post# 110246   2/17/2006 at 02:45 (6,657 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 110252 , Reply# 1   2/17/2006 at 03:18 (6,657 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 110267 , Reply# 2   2/17/2006 at 07:14 (6,657 days old) by toggleswitch (New York City, NY)   |   | |
Post# 110268 , Reply# 3   2/17/2006 at 07:28 (6,657 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 110274 , Reply# 5   2/17/2006 at 07:40 (6,657 days old) by tomturbomatic (Beltsville, MD)   |   | |
I think I have the use & care manual for the washer in this picture. |
Post# 110299 , Reply# 6   2/17/2006 at 10:11 (6,657 days old) by mickeyd (Hamburg NY)   |   | |
Post# 110305 , Reply# 7   2/17/2006 at 11:17 (6,657 days old) by unimatic1140 (Minneapolis)   |   | |
Thanks Glenn, you can see that this filter has the recirculation flume mounted right in the cabinet top, where as in my machine the mounting is under the top and the flume is sort of pointed downward so it would probably miss the filter pan if there was one mounted on top of the agitator. Mickey, you can see the one row of holes in all solid tub Easy washers at the top of the tub. |
Post# 110310 , Reply# 8   2/17/2006 at 11:59 (6,657 days old) by mickeyd (Hamburg NY)   |   | |
Funny you should bring up those holes, Robert!! I've been meaning to tell you since New Year's Day, after I read your stuff. You wondered WHERE DOES ALL THE WATER GO? because you can't see the holes, rather, slits in the Frigidaire. I wondered and wondered just like you did. And one day i was feeling around under the tub's rim and I felt the slits and it was as if I had discovered the secret of the universe. Then I yanked the pulsator forward which exposed the outer rim, and THERE THEY WERE--a million slits. It is one of my strongest memories. I was seven. Mikey |
Post# 110311 , Reply# 9   2/17/2006 at 12:09 (6,657 days old) by toggleswitch (New York City, NY)   |   | |
Post# 110312 , Reply# 10   2/17/2006 at 12:11 (6,657 days old) by toggleswitch (New York City, NY)   |   | |
