Thread Number: 50590
Impressions: Bosch S620 Dishwasher |
Post# 728222 , Reply# 10   1/17/2014 at 00:03 (3,752 days old) by washer111 ()   |   | |
Upper Rack |
Post# 728224 , Reply# 11   1/17/2014 at 00:05 (3,752 days old) by washer111 ()   |   | |
Apologies for the poor shots... Was in a hurry. |
Post# 728226 , Reply# 12   1/17/2014 at 00:05 (3,752 days old) by washer111 ()   |   | |
Up top |
Post# 728254 , Reply# 13   1/17/2014 at 03:32 (3,752 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Thanks for sharing these pictures. Did I miss you mentioning how old this machine is? (The font you are using is very hard to read). I guess this is a Bosch from the late 80's or early 90's? Do you know it's exact age?
I was wondering why you loaded the dishes in the lower rack as you did. On the right side they look loaded backward, the plates in the back are away from the center, that makes it more difficult to get them cleaned. Just like the plate in the back on the left side. This was a MOL or somewhat higher model. The TOL models had more cycles. |
Post# 728379 , Reply# 15   1/17/2014 at 19:47 (3,751 days old) by logixx (Germany)   |   | |
Post# 728407 , Reply# 16   1/17/2014 at 21:54 (3,751 days old) by washer111 ()   |   | |
I thought it was about ten years younger! In good shape for its age then... Anyone got an oxygen tank (or coffee)? I think I might faint... |
Post# 728553 , Reply# 17   1/18/2014 at 14:59 (3,750 days old) by supermaticjames (Donegal, Ireland)   |   | |
These are great machines! Bosch licensed their design to Hotpoint UK for their dishwashers. My 1986 model is more or less the same basic machine albeit in a different skin with a manual timer. |
Post# 728554 , Reply# 18   1/18/2014 at 15:04 (3,750 days old) by supermaticjames (Donegal, Ireland)   |   | |
Post# 745121 , Reply# 19   3/25/2014 at 18:18 (3,684 days old) by Dimitris (greece)   |   | |
OMG!!!!!!
That machine is gorgeous!!!!!!!!!!!! It is the first Bosch with double/split panel that I have ever seen online!!!!!!!! It is so similar with mine!!!!!!!!!!! Anyway, mine is early 90s with no split panels... SMI5082/17 www.automaticwasher.org/cgi-bin/T... I am lucky enough though because I have seen in somebody's house a bosch very very similar to that. It did have a salt container. It did have split panels. On/off push button switch and a rotary switch for choosing between only 3 programs. I know they bought it early 90s but I am sure it is an older model.... It's model is: SMU2200/00 These machines are really well built, the only place that they suffer is the door handle. through the years gets very fragile... Here is a diagram from Bosch website: |
Post# 745122 , Reply# 20   3/25/2014 at 18:19 (3,684 days old) by Dimitris (greece)   |   | |
Post# 745123 , Reply# 21   3/25/2014 at 18:21 (3,684 days old) by Dimitris (greece)   |   | |
Post# 745125 , Reply# 22   3/25/2014 at 18:23 (3,684 days old) by Dimitris (greece)   |   | |
Post# 745189 , Reply# 23   3/25/2014 at 22:23 (3,684 days old) by cornutt (Huntsville, AL USA)   |   | |
It's intersting to see the family similarities with my recent-model Bosch. |
Post# 745347 , Reply# 28   3/26/2014 at 15:52 (3,683 days old) by ricky5050 (Durham Britain)   |   | |
Hi I had a similar machine , and I'm sure yours is the same inside. I think you can alter the upper rack tho, slide it out as normal to load, the long silver arms will slide out too, the white clips on the end turn left or right this allows the upper rack to slide out completely , at the moment it's on it's lower level so slide it back in using the lower set of wheels and this will raise the upper rack to a higher level ( normal I'd say ) and give you better height in the lower rack for plates. Mine had a dial on right to select programme with a color selector above each program. I got it second hand and had it about 5 years before it started to fail.
Oh and mine was badged hotpoint ! But a Bosch in drag ! Richard |
Post# 745394 , Reply# 29   3/26/2014 at 20:00 (3,683 days old) by logixx (Germany)   |   | |
