Thread Number: 5099
POD...and thermostat questions on 40" Frigidare |
Post# 111434   2/22/2006 at 17:00 (6,638 days old) by wireman (Lansing, MI)   |   | |
What a GREAT GE stove!!! Late 50's, early 60's? Wish I had a mint one to solve my problem! Wonder when GE stopped the pushbutton controls? I've seen a few in white or coppertone that I guess to be late 60's early 70's... OK..now for a question..Have a 40" 1969 Frigidare Custom Imperial range (standard, not the Flair) 2 ovens- one is self cleaning. Neither oven will come up to temp...have replaced one element..didn't help. Small oven worked when I moved in; soon developed same low temp problem. I suspect both thermostat controls need to be replace or rebuilt... Any ideas where I might find help? Unfortunately, the new kitchen cabinets were built around this stove. So, buying a new 30" won't work; the only 40" ranges I see now are commercial ones, and expensive. I guess I could try to find another vintage, but afraid of the same problem occuring. If it weren't for the trusty 1954 30" Figidare in the basement, I'd have to give up baking! Please, any info would be appreciated! Thanks, Duane |
Post# 111459 , Reply# 2   2/22/2006 at 19:36 (6,638 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 111471 , Reply# 3   2/22/2006 at 20:31 (6,638 days old) by jamman_98 (Columbia, SC)   |   | |
I purchased a 1968 GE 40" range last year on e-bay and it has the push buttons and 2 ovens. The guy that I bought it from replaced the tempurature sensor so it works like new. (or it will when I get a home) My ex got a 40" GE range off e-bay and it has dials and I believe it is a 1970 model. Joe jamman_98 |
Post# 111508 , Reply# 4   2/23/2006 at 01:44 (6,637 days old) by dual-action ()   |   | |
Frigidaire still makes 40" ranges they have a couple different models starting around 1000.00 bucks go to frigidaire.com |
Post# 111601 , Reply# 5   2/23/2006 at 16:15 (6,637 days old) by wireman (Lansing, MI)   |   | |
Thanks folks for the ideas...Breaker is not tripped. Hadn't thought to check the voltage at the oulet, but should have- I am an electrician!! It is possible that the wire coming into the outlet, or the cord is not making good contact- something could be loose. Tend to think not though, burners work perfectly( the fat coils!), even the "Heat Minder". Could well be the temp. senor, but don't they come already attached to the thermostat knob? At least it did in the one I helped my Dad replace some years ago...I remember it being a bit tricky to thread the sensor and attached wire into the oven Glad to hear that 40" ranges are still available for a reasonable price...As nice as it would be to have a commercial range here (esp. with gas burners, but dual electric ovens-- my dream!!), the money would be better spent on other home projects. Again, thanks for the input, and if you know of a source for parts, please let me know! Gratefully, Duane |
