Thread Number: 51048
GE Filter Flow (1990)--stripped transmission spline |
Post# 733770 , Reply# 1   2/8/2014 at 15:16 (3,729 days old) by Yogitunes (New Jersey)   |   | |
for the most part, you will probably have to replace the tranny.....
although I have come across this once.....first pop the coupler out of the agitator, and slide it over the post, and drill a small hole straight thru, then with a properly sized expanding pin, slide thru and secure in place....then slide the agitator back on the coupler.... may not be the best solution, but it will work.... |
