Thread Number: 5110
Help...Maytag A700 |
Post# 111569 , Reply# 1   2/23/2006 at 12:21 (6,637 days old) by coldspot66 (Plymouth, Mass)   |   | |
Check the motor pulley. The edges may be wearing thin. Also check the belts to see if they are glazed. Does it agitate at normal speed, or does it seem to bog down or agitate slower than usual. Let me know. |
Post# 111574 , Reply# 2   2/23/2006 at 13:33 (6,637 days old) by sambootoo (Moody, AL)   |   | |
I have an A700 that won't agitate at all. Started out with very slow agitation, then picked up to normal speed, now won't agitate. The motor turns, belts just sit there and smoke. Is the tranny locked up or???? |
Post# 111578 , Reply# 3   2/23/2006 at 14:15 (6,637 days old) by bingwsguy (Binghamton NY)   |   | |
It agitates fine and at normal speed (from what I know of my Gram's). The noise seems to be coming from the bottom of the machine. The pulley is a good possibility....I will check it. |
Post# 111583 , Reply# 5   2/23/2006 at 14:39 (6,637 days old) by coldspot66 (Plymouth, Mass)   |   | |
Sambootoo, Are the springs in the sliding motor base maintaining tension on the belt? |
Post# 111602 , Reply# 6   2/23/2006 at 16:19 (6,637 days old) by bingwsguy (Binghamton NY)   |   | |
After doing 3 loads today, I went to see if agitation speed is still normal and it seems to be bogged down now...what does that mean? Also I have noticed a rubber smell when it first starts draining/spinning. |
Post# 111611 , Reply# 7   2/23/2006 at 17:27 (6,636 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 111620 , Reply# 8   2/23/2006 at 18:03 (6,636 days old) by bingwsguy (Binghamton NY)   |   | |
I am a real novice here..does that mean the belt is bad and I should start there? |
Post# 111621 , Reply# 9   2/23/2006 at 18:13 (6,636 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 111630 , Reply# 10   2/23/2006 at 19:02 (6,636 days old) by bingwsguy (Binghamton NY)   |   | |
The only way to tell is to pull it apart and look right? |
Post# 111638 , Reply# 11   2/23/2006 at 19:46 (6,636 days old) by coldspot66 (Plymouth, Mass)   |   | |
Bingwsguy, See the 5th post in this thread about turning the main center pulley. |
Post# 111642 , Reply# 12   2/23/2006 at 20:00 (6,636 days old) by bingwsguy (Binghamton NY)   |   | |
coldspot66 and goatfarmer...thanks for the advice. Coldspot66, I read the 5th post and will try that. I have a service/repair manual coming this week to show me the "how to" if I need to tear apart. |
Post# 111655 , Reply# 13   2/23/2006 at 20:56 (6,636 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 111749 , Reply# 14   2/24/2006 at 09:14 (6,636 days old) by sambootoo (Moody, AL)   |   | |
thanks for the advice. The belts seem to be held in good tension, sliding base is working fine, but, no, I cannot turn the pulley counter clockwise for agitation. Sounds like bad news to me.. |
Post# 111750 , Reply# 15   2/24/2006 at 09:17 (6,636 days old) by coldspot66 (Plymouth, Mass)   |   | |
Sounds like a busted gear in the tranny. Not good news for sure! |
Post# 111782 , Reply# 16   2/24/2006 at 13:04 (6,636 days old) by fixerman ()   |   | |
Broken gear or stuck agitator shaft. |
Post# 112970 , Reply# 19   3/2/2006 at 20:57 (6,629 days old) by bingwsguy (Binghamton NY)   |   | |
Bobby...Thank You for the suggestion. I will order a pump as that is not very expensive and if that solved your problem, hopefully it will solve mine as well. How long were you in Syracuse? Joe |
Post# 113124 , Reply# 20   3/3/2006 at 12:04 (6,629 days old) by deeptub (Carbondale, IL)   |   | |
There is confusion here--two people have reported different problems in the same thread and the replies have become confused as to what machine they're in reference to. Bingwsguy, I wouldn't replace the pump until you have replaced the belts. Maytag uses special belts that are cloth covered. The reason is that the drive belt is designed to slip until the tub gets up to full speed--it acts like a clutch. Eventually the fabric wears thru to rubber, and you get the chirping, and burning rubber smell. They will SEEM like they have proper tension, and might even look like they're in fine condition to a casual eye. But if the fabric has worn through in even one small place, there will be chipring and smells, and eventually outright squealing. For this reason, you have to use the cloth covered maytag belt (or a cloth covered tractor-stye belt in the correct size). A plain rubber automotive-style belt will not work at all. This is actually a clever design--let an inexpensive and easy to replace belt wear out, rather than an expensive clutch buried in the depths of the machine. T. |
Post# 113137 , Reply# 21   3/3/2006 at 14:14 (6,629 days old) by bobbyderegis (Boston)   |   | |
Joe, I moved to Boston in 1990, but the family is still in Syr. It's a great place to be FROM! Let me know how the old girl makes out. Bobby in Boston |
