I searched and found several threads that said the agitator drive belt for the A50 was inexpensive and easy to locate...yet I have spent weeks trying. Does anyone know the source of a belt? I just need the belt that drives the agitators, if I can find a spin/pump belt that would be a plus. Thanks!
Changing the spinner drive belt would be a NIGHTMARE. You would have to remove the drive block and motor mount to get the belt out. You might find a belt that might fit at a local hardware store or online. At Mc-Master-Carr, they have urethane belts that you might find one that fits. Hope this helps.
