Thread Number: 51264
old kitchen aid not cleaning properly |
Post# 736538 , Reply# 6   2/20/2014 at 13:19 (3,718 days old) by chachp (North Little Rock, AR)   |   | |
These come up fairly often on eBay if no one here has a spare. I had the same issue with mine and it is a very easy fix. Just remove a couple of screws and replace with the new one and your machine will get back to providing those stellar results. Just have to find one and you will.
Watch eBay. Looks like one just sold a couple of weeks ago. |
Post# 736540 , Reply# 7   2/20/2014 at 13:29 (3,718 days old) by coldspot66 (Plymouth, Mass)   |   | |
I do have a used one, if you can't find new. You can have it for the cost of shipping. I live in Plymouth. |
Post# 736576 , Reply# 8   2/20/2014 at 16:41 (3,718 days old) by christfr (st louis mo)   |   | |
Post# 736587 , Reply# 9   2/20/2014 at 17:08 (3,718 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Not quite as fancy but UNsweetened lemon Kool Aid will get rid of a lot of the hard water scale |
Post# 737257 , Reply# 11   2/23/2014 at 21:57 (3,714 days old) by stevet (West Melbourne, FL)   |   | |
Daisy, the white shoulder should remain down in the wash arm support and should not come up which will block the water from coming out of the lower wash arm. Just want to make sure that you have got it right. |
Post# 737287 , Reply# 12   2/24/2014 at 01:44 (3,714 days old) by PhilR (Quebec Canada)   |   | |
Stevet, I also have an issue with an Hydrosweep that won't turn on a KDC-7. The support is brass on mine. It does turn relatively easily (freely) by hand but it doesn't move with water pressure. The filter is clean and free of any scale but the plastic on the surface that contacts the brass support and brass ring is slightly worn. Since this is a single wash arm, I thought it would have more than enough water pressure to turn but it doesn't. I haven't tested my KDS-58 yet but I bet it might have some trouble moving too as the wash arm's bushing seems worn (the 18 has the same style white plastic support as Daisy's washer). |
