Thread Number: 5184
adjustible temperature on 1 setting dryers |
Post# 112353   2/27/2006 at 13:09 (6,632 days old) by awooff (Peoria, Illinois)   |   | |
Post# 112355 , Reply# 1   2/27/2006 at 13:27 (6,632 days old) by coldspot66 (Plymouth, Mass)   |   | |
Fixed temperature dryer thermostats are not adjustable. You could put a lower temp thermo in, say 125 degrees, but would be too low for towels and heavy fabrics. Drying would take longer. |
Post# 112405 , Reply# 2   2/27/2006 at 17:39 (6,632 days old) by spinout (Phoenix)   |   | |
Exactly what Kenmore do you have? |
Post# 112428 , Reply# 3   2/27/2006 at 19:16 (6,632 days old) by appnut (TX)   |   | |
How old is the Maytag? I believe they selected a temperature t-stat that aws kinda all-fabric for no temp setting dryers. A case in point, the electronic control dryers that didn't have specific temp buttons to the right were an all-fabric temp. The only difference between regular & wash'n'wear/perm press is a slightly dryer sensing of the fabrics and a longer cool-down with the bell dinging periodically. Gansk1 told me this. As for the Kenmore, how old is that dryer and what does it look like? It could be a softheat model which gradually reduced the temp as the timer counted down the minutes or just does have one temp.
Post# 112477 , Reply# 4   2/27/2006 at 22:09 (6,632 days old) by toggleswitch (New York City, NY)   |   | |
Post# 112651 , Reply# 7   3/1/2006 at 08:31 (6,630 days old) by toggleswitch (New York City, NY)   |   | |
22,000 BTU/hr @ 3.4 BTU/watt= 6,470+/- watts. IIRC electric dryers here have a 5,200 watt heating element. So I have to agree, the heat inputs are close. This makes more sense when we factor in nearly 100% gas efficiency(on site) in that even the heat from the products of cumbustion is used to help dry clothing. As with the burning of all fossil fuels, some water / moisture is created so that the flame would have to be a bit "bigger/stronger" than the exact electircal equivalent which does NOT produce moisture. It can be argued, perhaps, that a gas dryer is less "harsh". www.simetric.co.uk/sibtu.htm... CLICK HERE TO GO TO toggleswitch's LINK |
Post# 112784 , Reply# 10   3/1/2006 at 20:59 (6,630 days old) by awooff (Peoria, Illinois)   |   | |
