Thread Number: 52188
Finally! The 57 Whirlpool dishwasher LOOKS like a dishwasher again |
Post# 745760   3/28/2014 at 10:07 (3,682 days old) by turquoisedude (.)   |   | |
Back in June of 2011, I saw an ad on the Hartford, CT area craigslist for 'vintage Whirlpool dishwasher parts' in the 'FREE' section. Of course I had to inquire about it and it turned out to be a WP57 70000 dishwasher, but it had been completely torn apart when it was removed from it's original installation.
"Some assembly required" was an understatement to say the least... |
Post# 745761 , Reply# 1   3/28/2014 at 10:11 (3,682 days old) by turquoisedude (.)   |   | |
It was a challenge... I had zero information about this machine (except a schematic wiring diagram) and there were lots of issues...
The cabinet frame had been cut. No problem! Phil welded it back together for me! The tub had rust damage. FEH! Nothing a little fibreglas patching kit and JB Weld didn't cure! The last big hurdle - how to get the stinking timer box back together. Easy! Just take a photo of one that was still assembled! Thanks to Mike (dishwashercrazy) for letting me photograph this one in his collection! And yet armed with all this information, the damn thing still sat in the corner of the Ogden laundry... Until this week!! |
Post# 745764 , Reply# 2   3/28/2014 at 10:13 (3,682 days old) by turquoisedude (.)   |   | |
Post# 745766 , Reply# 3   3/28/2014 at 10:17 (3,682 days old) by turquoisedude (.)   |   | |
Now, here's where things get even more interesting...
The front door panel of this machine had been almost mint, but the former owner managed to scratch it badly. When I was examining it this week, I noticed something most unusual. To confirm what I observed, I ever-so-carefully chipped off some more paint from the underside of the door panel. Yee-haw! Looks like I struck copper!! |
Post# 745771 , Reply# 4   3/28/2014 at 10:24 (3,682 days old) by turquoisedude (.)   |   | |
I had to test the lower panel as well, but darn it, it's just plain steel...
To the best of my knowledge, the only copper-fronted D&M dishwasher was a Chambers re-badge. I wonder if the Whirlpool production run was missing door panels and they just spray-painted a bunch? I'd love to get the 'rest of the story' on this one!! So back to the dishwasher, I ran it through a cycle with no water and it seemed to run just fine (despite my wiring and the fact that I had to re-assemble the timer!) I may have an issue with the drain valve solenoid and I wonder if I shouldn't just put in some kind of electric pump. This was a gravity-drain model and well, I don't know where I could possibly install something like that... I also think I should make an effort to treat this tub to a 'Wite-Coat' treatment. That was the stuff I used on the still-driving-me-nutty Inglis wash tub and it put on a really nice smooth finish. So, just a little more futzing around and I'll be doing dishes D&M front-load style at last... LOL |
Post# 745776 , Reply# 5   3/28/2014 at 10:30 (3,682 days old) by ken (NYS)   |   | |
Post# 745781 , Reply# 6   3/28/2014 at 10:35 (3,682 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 745807 , Reply# 7   3/28/2014 at 11:49 (3,682 days old) by turquoisedude (.)   |   | |
Ken: Wite-Coat is made by the same folks who make POR-15. It's a two-part enamel epoxy that's waterproof. It's intended for sinks and bathtubs, but by golly, it worked fine on the Inglis tub! One thing I learned the hard way about this stuff, though is don't mix up too much at a time. It sets way faster than they say on the can!! Oh, and if you do use it, I'd recommend using it outdoors - the stuff gives off some pretty potent fumes!!
Ben - I did a lot of scrubbing already (check this 'before' shot) and I was afraid of damaging what was left of the finish. Also, I kinda wanted to hide the POR-15 rings where I repaired the motor and heater mounting holes. I'll see how ambitious I want to get with this... LOL |
Post# 745811 , Reply# 8   3/28/2014 at 12:00 (3,682 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 745824 , Reply# 9   3/28/2014 at 13:10 (3,682 days old) by turquoisedude (.)   |   | |
Post# 745825 , Reply# 10   3/28/2014 at 13:21 (3,682 days old) by rollermatic (cincinnati)   |   | |
Post# 746324 , Reply# 11   3/30/2014 at 17:09 (3,680 days old) by turquoisedude (.)   |   | |
The weather in Ogden was pretty crummy this weekend - just right for more fiddling around with machines and the '57 Whirlpool got all my attention!
Here's the impeller re-installed after a few tries. I needed to do some serious messing around to get the clearance from the bottom just right. The new bolts that I used to mount the motor were a wee bit higher than the original ones... The impeller still needs some TLC but amazingly enough, it's the original one and there are no nicks or cracks in it. |
Post# 746325 , Reply# 12   3/30/2014 at 17:10 (3,680 days old) by turquoisedude (.)   |   | |
Post# 746330 , Reply# 13   3/30/2014 at 17:14 (3,680 days old) by turquoisedude (.)   |   | |
Now that upper rack sure looks like it's roto-rack cousin, doesn't it?
But what is the square support in the middle supposed to do? My guess is to channel water that splashes across the tub top down toward the cutlery basket. However, that is just one of my wild guesses, so if anyone knows what it's really for, please let me know!! |
Post# 746332 , Reply# 14   3/30/2014 at 17:18 (3,680 days old) by turquoisedude (.)   |   | |
Oh, right, here's what the machine looks like with the panels on!
I did not touch that main door panel for the time being, but I think I want to take it down to the copper surface I discovered. I think I might just paint the lower panel turquoise... An interesting contrast to say the least... One thing I still have to do - drill a couple of new holes for the lower panel mounting screws. The fact that the cabinet got cut and welded back together made for some challenges in trying to get the panel attached again. After fighting it for over an hour, I thought, "to hell with this" and figured I could just drill new holes and be done with it. Maiden wash coming soon... |
Post# 746429 , Reply# 15   3/30/2014 at 23:31 (3,679 days old) by PhilR (Quebec Canada)   |   | |
Post# 746478 , Reply# 16   3/31/2014 at 05:08 (3,679 days old) by chachp (North Little Rock, AR)   |   | |
Post# 746500 , Reply# 17   3/31/2014 at 07:24 (3,679 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
I love the AUTOMATIC DISHWASHER on the front but tell me are you saying that front panel IS solid copper or finished in copper??
My favorite metal BTW< in case you hadn't noticed my kitchen..
I also think if you just run a few loads thru that impeller will clean up on its own. They are very delicate i find.
Post# 746508 , Reply# 18   3/31/2014 at 07:45 (3,679 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
That's coming together nicely, Paul. I love the graphics and WP logos on the front. I have a magazine story about a "open floor plan" house built in 57 with all WP appliances and this dishwasher. It's nice to see inside after staring at the pictures for years!
Post# 746531 , Reply# 19   3/31/2014 at 10:00 (3,679 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
Post# 746590 , Reply# 20   3/31/2014 at 16:56 (3,679 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Any chance the "boxy" thing might allow for the top rack to be moved up/down? |
Post# 747000 , Reply# 21   4/2/2014 at 05:19 (3,677 days old) by CHRISTFR (st louis mo)   |   | |
Post# 748457 , Reply# 22   4/7/2014 at 13:25 (3,672 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 753048 , Reply# 23   4/27/2014 at 08:00 (3,652 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 754048 , Reply# 24   5/1/2014 at 01:33 (3,648 days old) by dishwashercrazy (West Peoria, IL)   |   | |
