Thread Number: 53583
Frigidaire 2140 Stops On Heavy Setting |
Post# 759621 , Reply# 1   5/26/2014 at 09:45 (3,628 days old) by GrumpyOldMan ()   |   | |
Shortly after the motion stops, the start button light blinks and then the whole thing shuts off. |
Post# 759682 , Reply# 2   5/26/2014 at 17:42 (3,627 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 759899 , Reply# 4   5/27/2014 at 20:57 (3,626 days old) by PassatDoc (Orange County, California)   |   | |
I have a 2140 which I bought in 2006. Eight years of perfect service, has never needed a repair or any service. |
Post# 760077 , Reply# 5   5/28/2014 at 16:53 (3,626 days old) by logixx (Germany)   |   | |
Post# 760110 , Reply# 6   5/28/2014 at 19:33 (3,625 days old) by lotsosudz (Sacramento, CA)   |   | |
Post# 760168 , Reply# 7   5/29/2014 at 01:38 (3,625 days old) by PassatDoc (Orange County, California)   |   | |
I ran it again tonight, so far so good! :) |
Post# 761992 , Reply# 9   6/6/2014 at 20:24 (3,616 days old) by logixx (Germany)   |   | |
Post# 761999 , Reply# 11   6/6/2014 at 20:54 (3,616 days old) by GrumpyOldMan ()   |   | |
If I read the lights correctly, the error code is E52 - Bad signal from tacho generator. I am not sure what that means. |
Post# 762012 , Reply# 12   6/6/2014 at 22:30 (3,616 days old) by logixx (Germany)   |   | |
Hm, the link works for me...
I just tried to send you the manual to you gmx. It's big - not sure if your inbox allows such large files. The manual says to: Disconnect the plug from the drive motor and measure the resistance pins 4 & 5 in the motor. If the reading is between 105 & 130 Ohms, replace the speed control board. If the meter reads other than between 105 & 130 Ohms, replace the motor. |
