Thread Number: 538
Kenmore front loader needs new bearing/drum?
Post# 49384   11/17/2004 at 18:48 (7,098 days old) by Wash-me-blues ()
I have a Kenmore front loader, model 29052, which worked fine until the other day when the drum started REALLY clanking on spin cycle. I took it apart and sure enough, the main bearing/spindle assembly (which seems to be fused with the pulley) is shot. Apparently it's a one-piece job? Any help or cross reference for parts to replace it (aside from the $274 Repairclinic.com wants for a new tub assembly) would be greatly appreciated. Thanks!
Post# 49398 , Reply# 1   11/17/2004 at 21:20 (7,098 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
As I understand it...
jetcone's profile picture
That is the best you are going to do for that machine. My Gibson is starting to do the same thing and JOhn told me it isn't worth the money to fix as a paid repairman when you can go out and buy a new machine for $500. Bad design on their part. I really like the washability of my Gibson too! Mine is about 5 years old which is way too young.
IF you have the time then it is worth the part for another 5 years I guess.
cheers
jet
Post# 49412 , Reply# 2   11/18/2004 at 00:23 (7,098 days old) by Launderess (Quiet Please, There´s a Lady on Stage)
launderess's profile picture
Rear bearing failure is a "common" complaint of the FriGeMore units,with about 5 years being the average "break time". If a unit lasts beyond the 5 years it seems it will survive the duration. By "common" I don't mean all units suffer bearing failure, but in numbers that it is an often reported problem
You were given the correct information in that the entire drum assembly has to be changed not just the bearings. As this is a costy repair job,you probably are better off just buying a new washer.
You can check fleaBay, now and then the bearing/drum assembly for these units pops up.
I'm curious to know if recent generation models of FriGeMore washers have noted and corrected this problem. Or is it always blamed on customer error? One person posted that Sears told him the bearings went out because he used too much detergent and that caused the bearings to fail, and they would not replace the unit.
Launderess
Post# 49485 , Reply# 3   11/19/2004 at 02:33 (7,097 days old) by Wash-me-blues ()
Update!!!!
So I was able to actually remove the pulley (with a puller) thereby allowing the outer drum to be seperated, revealing the inner drum (tub) and spindle/spider assembly and BANG! two of the three 'spider' arms are broken! Now I'm willing to bet that not only is this a definite maunufacturing defect but since there seems to be common agreement that these machines 'last about five years' and due to the overwhelming amount of labour involved, the main bearing deficit is actually this problem, which IS covered under Kenmore's 'Lifetime warranty'. I just can't wait to explain that fact to them! Stay tuned! CRT
Post# 49551 , Reply# 4   11/19/2004 at 22:06 (7,096 days old) by Wash-me-blues ()
Sears to the rescue!!!!!
I managed to find a Sears parts/repair center and calmly walked in with my inner stainless steel (with spider and spindle attached, of course) and politely said "I have a parts issue that I believe is covered under warranty". The counter man was astonished to see a machine disassembled to that point (it's really not rocket science, as I'm sure some of the appliance buffs on this forum can attest to!), looked up my name and purchase date, mentioned the machine itself was out of warranty (by four months) and then asked to see my brochure with the "Lifetime Warranty on stainless steel drum" notation. He then said, "yup, you're right", looked up the part, placed a drop-ship order for it, and had the manager and myself sign it! Talk about service! Man, I haven't had that type of interaction on the retail level in YEARS!! I'm inclined to think this clerk and Sears deserve a written letter of praise, for nothing else than to help balance the complaints. Sure, it'll take two weeks+ for the part to arrive but sure beats spending $550+ to replace what otherwise is a perfectly functioning machine. Wash-me Blues
Post# 49556 , Reply# 5   11/20/2004 at 00:19 (7,096 days old) by DADoES (TX, U.S. of A.)
dadoes's profile picture
Bwahahaaa!! BRAVO!!
Post# 49576 , Reply# 6   11/20/2004 at 09:51 (7,096 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
Bwahahaaa??
Dadoes how do I pronounce that one?? Its kind of like Brewhaha but yet.................not
Wash ME that is an incredible story! Of course I can't try that with my Gibson since it is not a Kenmore and I bought it from an independant dealer in the Washington DC area who will remain unnamed since he is a personal friend and mentor etc etc...
Have fun on the reassembly! Use lots of Anti-seize when you reinstall it!
jet
Post# 49579 , Reply# 7   11/20/2004 at 10:29 (7,096 days old) by scott55405 ()
Jet, when you "pronounce" it, think of those mad scientist types from the Saturday morning cartoons...there would of course be a certain inflection required as well. ;-)
Post# 49588 , Reply# 8   11/20/2004 at 15:26 (7,096 days old) by Brent-Aucoin ()
Way to go!
That is great about them treating you so kind.
I am sure that 99% of the people just get rid of them, not knowing it is a defect like yours.
Would they have paid for the labor for a tech to do it?
Congradulations!
Brent
Post# 49589 , Reply# 9   11/20/2004 at 15:30 (7,096 days old) by Brent-Aucoin ()
Jon Call Electrolux
Hey there.
I bet if you call Electrolux and tell them your story, they would honor it and ship you the part. I am sure that Sears will go after them for the price of the part that Wash-Me got.
It might be worth a try.
Brent
Post# 49615 , Reply# 10   11/21/2004 at 06:29 (7,095 days old) by wringingwet (Walterboro South Carolina)
I had the same problem with mine a few years ago
wringingwet's profile picture
Greetings fellow washer fans
I had the same problem with my Frigidaire Crown Front loader after five years. and with many emails they finally refunded me about 80% of the purchase price.
Philippe
Post# 49844 , Reply# 11   11/24/2004 at 22:34 (7,091 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
Not a bad Idea
Hi Brent:
How are you ?? Come on down to Boston!
I may try that calling Electrolux , I checked my tub this weekend and it is not as loose as I remember but it is not new either.
jon
