Thread Number: 53819
Need help |
Post# 761542 , Reply# 1   6/4/2014 at 20:33 (3,613 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
You'll probably need to pull the front panel off of the front, disconnect the rubber hose that goes from the pump and quickly put it in a bucket as the water from the dishwasher should drain out quickly. I'll let one of our knowledgeable Kitchenaid specialists take over from here. |
Post# 761934 , Reply# 2   6/6/2014 at 15:29 (3,611 days old) by laundromat (Hilo, Hawaii)   |   | |
Did you recently replace your disposer? In selling appliances for decades, I learned that some customers that buy disposers and install it are unaware of the need to punch out the plastic plate to open the drain there up for dishwasher drainage. When that happens, the water in the dishwasher has nowhere to go so it lays stagnating in the dishwasher. Check the drain hose for any blockage too. |
