Thread Number: 54320
Maytag Neptune Water Level |
Post# 767017 , Reply# 1   6/30/2014 at 16:53 (3,588 days old) by Yogitunes (New Jersey)   |   | |
you should be able to adjust the level.....there are screws on the pressure switch, usually colored red, that will have an effect on the level....
are you measuring cycle for cycle....meaning during certain times, like 'wash' there may not seem to be enough, but then bleach will be dispensed, and more is added....and before the first drain, it may add more.....and usually the last rinse seems to have the most....then it is really splashy..... I thought a few of my 5500 were not adding enough, until I watched the whole cycle.....the idea was always to concentrate as much detergent with minimal water during the first part of the wash as a deep scrub, as the stains start to release, then more water suspends it into the water, ready to be drained away.... let us know how you make out... |
Post# 773421 , Reply# 2   7/27/2014 at 12:57 (3,561 days old) by electronicontrl (Grand Rapids, MI)   |   | |
Were you able to add to the water level?
I have the MAH4000 at home and the MAH7500 at a friend's house. The service literature states the 5500, 6500 and 7500 use 1" less water per fill compared to the MAH4000. I'm not sure what that corresponds to in gallons. I'm going to guess maybe a gallon per fill. |
Post# 773425 , Reply# 3   7/27/2014 at 13:17 (3,561 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
Post# 773431 , Reply# 4   7/27/2014 at 13:36 (3,561 days old) by electronicontrl (Grand Rapids, MI)   |   | |
Post# 773443 , Reply# 5   7/27/2014 at 15:36 (3,561 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
Yes Michael I have the Asko made Maytag! It's my favourite machine! It is superbly built and washes fantastic!
Darren
