Thread Number: 54433
Hoover Twin Tub |
Post# 768208 , Reply# 1   7/5/2014 at 16:45 (3,582 days old) by cam2s (Nebraska)   |   | |
Here are some more pictures of the pump |
Post# 769244 , Reply# 2   7/8/2014 at 21:01 (3,579 days old) by bradross (New Westminster, BC., Canada)   |   | |
soaking the parts in vinegar to loosen up the corrosion and sediments? I no longer have my Hoover 0611, but when I first got it (second hand), the pump was also in rather bad shape. However, it cleaned up nicely and after lubing it a bit, worked beautifully.
One thing to note, Hoover pumps are notorious for leaking around the joint where the two halves fit together. I ended up resorting to caulking completely around the joint, as the O-ring just didn't seem to be enough. Good luck, Cameron! Hope it all works out. Parts are next to impossible to find in Canada or the U.S., with the exception of the U.K. and Australia. |
Post# 769247 , Reply# 3   7/8/2014 at 21:10 (3,579 days old) by Launderess ![]() |
In one's stash but sold it off to a member.
Think have one or two spare of the older pumps but had always maintained keeping them as back up units for my TT. Though for the use that machine gets the current pump may last the duration. However it was a NOS pump to replace the one which came with the machine as it was shot Hoover TT's had a infamous weak spot, their pumps. You can try hunting around including Oz and UK or EU eBay sites or washing machine spares for another. Though by this time they are becoming very hard to find NOS. After Hoover ceased UK production over the years spares began to run out. Every now and then someone will come upon a shop or repair person that has a (forgotten) stash, but again as time goes on things are looking grim. Great thing about Hoover TT pumps is they ran off a belt, so it didn't matter about the power source. Long as the motor ran so would the pump assembly. This means where ever you are able to find a pump for your machine from Scotland to Sydney it should work. |
Post# 769275 , Reply# 4   7/8/2014 at 22:26 (3,579 days old) by barcoboy (Canada)   |   | |
