Thread Number: 54546
You've never seen a dishwasher like this! |
Post# 769440   7/9/2014 at 15:42 (3,578 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Introducing the FT-1000 with Advansys energy recovery. This is a dishwasher with a capacity of over 14,000 dishes per hour! It requires no pre-scrapping and uses only 58 gallons of 180f rinse water per hour. The machine is also ventless as it reuses the waste steam to heat itself. This DW also has automatic cleaning and deliming cycles as well as on board diagnostics. HMM, I wonder who makes it? Click the link and find out. This is really cool.
WK78 CLICK HERE TO GO TO whirlykenmore78's LINK |
Post# 769491 , Reply# 1   7/9/2014 at 18:05 (3,578 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 769564 , Reply# 2   7/9/2014 at 21:20 (3,578 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 769732 , Reply# 6   7/10/2014 at 12:15 (3,577 days old) by joe_in_philly (Philadelphia, PA, USA)   |   | |
Post# 769737 , Reply# 7   7/10/2014 at 12:54 (3,577 days old) by JeffG ()   |   | |
Good grief. Can it make everlasting gobstoppers? |
Post# 769782 , Reply# 9   7/10/2014 at 16:15 (3,577 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Remember that the dishwasher has 5 tanks that are cleaned and refilled every 2 hours or after each meal service.
Capacities are as follows ASR-7.2 gal Pre-wash, wash, power rinse-40gal EA. Dual Rinse-7.2 gal. This would mean the machine is holding 134.4 gallons of water just from it's initial fill of the tanks. It takes a lot of water to fill a DW of this size. WK78 |
Post# 769803 , Reply# 10   7/10/2014 at 19:07 (3,577 days old) by washer111 ()   |   | |
Does these commercial dish machines feature only 1 rinse for sanitising?
Doesn't this meant the dishes are poorly rinsed, even if Rinse-Aid is used? |
Post# 769810 , Reply# 11   7/10/2014 at 19:47 (3,577 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
This dishwasher rinses the dishes 3 times. there is the Power rinse and dual rinse then the final 180f rinse. The first 2 are recycled water sprayed through a pump after the respective tanks have been filled. The final rinse water counter flows through the tanks until it reaches the ASR phase then goes down the drain.
WK78 |
Post# 770439 , Reply# 12   7/13/2014 at 03:43 (3,575 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
I wonder if stevet has worked on any of these yet.
The on board diagnostics...I don't know... If it's anything like the LXI series glass washer we have at the restaurant, it's a nightmare once the boards start to go south. The UM and WM series were mechanical times and trouble free. I've decided to set up a cot in the attic for a service tech because of the frequent service calls on the LXI. |
